Hi all, Having just received my Mini210, I've installed CE6.0 on it as this is the OS that I will be using in my product (I'm using the 210 as a dev tool, as we don't have the end-hardware yet) and I'm noticing a strange issue with the LCD. The longer the system sits running, the more washed out and flickery the image on the LCD becomes. If you do Start->Suspend a few times it gets better again. Anyone got any idea on why this is happening (is it just my device?) and if so, has anyone managed to fix it? Cheers, V
Display issues with Mini210S CE BSP
On similar note, after a certain timeout, the screen goes white and sometimes with these vertical lines of different colors. How do you disable such thing? I tried disabling timeout in wince, no dice.
NothinRandom: I believe this occurs because power to the LCD driver on the 210 is killed, but LCD power remains on. My guess would be that the driver is coded to be killed when the system power state drops from "On" to "User Idle" or "System Idle", but that's just a guess. Investigating this is on my "todo list" ;)
Thanks Voodoo. I know there's a idle time that you can get from pinvoke. Maybe this will work. http://www.pinvoke.net/default.aspx/coredll.systemidletimerreset
