Hello, i have mini6410... i could install WinCE6 and Android 2.3.4 through SD Card several times. but when i decided to install another image of Android, the NAND flash corrupted... after that i am not able to install any image ): for example when i push my SD Card into Mini6410 (with NK.bin, NBOOT-RAM256.nb0,...) while S2 is in SDBOOT state,it can "Load NK.bin from SD card..." %100, but it can not install unpacked NK.bin. the progress fills until %6 and suddenly prompts "Write NAND Error" how to solve my problem. also i could not use dnw to format NAND flash... because my PC don't know mini6410 at all(via the blue cable...) ))):
Write NAND Error
i could connect to pc via serial cable and usb, now [USB:OK] but when i try to install an image using dnw, it says same error(Write NAND Error) e.g. installing from SD Card and dnw have same operations. also i saw somethings like this: --------------------------------- (...) Skip block 0x3b6 Skip block 0x3b7 Skip block 0x3b8 Skip block 0x3b9 Skip block 0x3ba Skip block 0x3bb (...) Skip block 0x7fb Skip block 0x7fc Skip block 0x7fd Skip block 0x7fe Skip block 0x7ff Installing yaffs-image failed --------------------------------- can anyone help me ?? i am very sad ))))): (sorry for poor english.)
well,what is the solution? (software or hardware?) if i change the samsung nand flash on board, will it solve ? this is my email hesam_um@yahoo.com i can use translate.google.com, please type in your language if your english is poor where are you from?(what is your language?)
hello all, ************************** ************************** i am very happy... problem solved... i bought a new Samsung Nand Flash... (it is K9F2G08U0B) now WinCE is installed on mini6410 :)))))))))))))))) Thanks GOD ************************** **************************
