Hi, Is there a way to burn superboot on Linux, without using SD Flasher ? Thanks.
Burn superboot on Linux ?
Someone has posted that dd if=Superboot210.bin of=/dev/sdcard seek=1 is the thing you want, the seek steps past the partition table. Having said this my 210 only gets to print "Board type: 2", then hangs. Though without all this it just screams at me with the beeper thing, so something meaningful is happening, just not sure if this is all that needs to be written. Painfully retarded to have such an important thing as SD-Flasher closed source, there is nothing in it aside from crap coding that should warrant this. If I could get my builds to work on the i.mx this would be a solid reason to dump the 210, just making my life hard for no reason.
I found this quite interesting thread : http://www.friendlyarm.net/forum/topic/3285 Unfortunately, even after formatting my SD card with the official SD Flasher tool (on Windows), I don't see any LED flashing nor hear any beep :( Is it possible that the SDCard is not compatible? ( http://www.amazon.com/gp/product/B001W1BSM0 ) I have no RS232 cable to check the boot log. By the way, I have android installed in the NOR, and the SD card is recognized so that's definitely not the S3C6410's fault.
