HI, we Bought mini6410 board And There is Mini6410-WinCE6-Suite-1220.exe File on it's DVD that after run this file Creates mini6410 platform Builder into Project into OsDesign Folder. I Open This project with VS2005 and before any build operation i Clicked On Catolog item view menu item after that 14 error creates in error tab. please help me how get ride of these errors. Thank you very much.
Error On Loading mini6410 PlatformBuilder Project
What version of windows ce updates do you have installed? R2 or R3? Do you have the latest bsp? You may want to download the latest DVD disc image from the FTP server and get the later bsp.
ok. the latest BSP for wince 6 mini6410 seems to be version 1142. do you have the latest iso image? mini6410A is the image that holds the bsp the bsp is date 10/19/2011
I Downloaded The last DVD Mini6410A-20120726.iso And After Extract Run Mini6410-WinCE6-Suite-1230.exe but tha same errors occured . this means after loading mini6410-en project in OSDesign Folder There is No Error But When Click On Catolog Item View In View\Other Windows Menu 15 Error Generates Automaticly
Hi, i am not sure if installing a newer version on top of an existing bsp package creates any problems. also, i have not come across a way to uninstall an existing bsp automatically. obviously it can be done manually, but this will require some exact info on what files are installed where etc kindda cumbersome. if you happen to be using vmware workstation 7 or 8, you can take snapshot before installing a new software/bsp/sdk or whatever and then roll back if necessary. alternatively you can try and clean and rebuild your osdesign after you installed the new bsp and see if that helps. or create a brand new OSDesign project, see if that is error free. i am not a big fan of installing multiple bsp's on the same install of vs2005, platform builder can be finicky, again vmware workstation can come in handy here. vmware esxi 5.0 is free, this can allow you to have multiple operating systems running simultaneously depending on your processor (64bit cpu is recommended with lots of ram, 32gb is max usable with the free version) great option for developers and OS builders!! you will need to post details on exact errors you are receiving to provide help
