Hi all, cant boot the kernel.
this is the serial output.
P broadcast 2
*** Unhandled DHCP Option in OFFER/ACK: 28
DHCP client bound to address 192.169.10.20
*** Warning: no boot file name; using 'C0A90A14.img'
TFTP from server 192.169.10.10; our IP address is 192.169.10.20
Filename 'C0A90A14.img'.
Load address: 0x32000000
Loading: #################################################################
############checksum bad
done
Bytes transferred = 2517028 (266824 hex)
MINI2440 # bootm 0x32000000
Wrong Image Format for bootm command
ERROR: can't get kernel image!
MINI2440 #
as you see i loaded the image into address 0x32000000
but cant boot the kernel.
the file is C0A90A14.img zImage_T35 which works from supervivi>boot
command.
any ideas please?
uboot tftp bootm
solved- intsall uboot-mkimage and run mkimage -A arm -O linux -T kernel -C none -a 0x30008000 -e 0x30008000 -d ./zImage_T35 ./uImage
You can use address 0x30000000. But you cannot load zImage via u-boot. Well, maybe you can but it won't boot. Convert zImage to uImage first just like ymymymym did.
