Hi, i want to formatting the NAND flash in SBC2410...how can i do tht.. i connected my jtag and i installed vivi after that the DNW shows like this..keep on saying booting linux...i cant enter into supervivi mode... 1.Can u say how can i format NAND completely and how to install the BIOS in it via H-JTAG? 2.my friends says i need two files to do tht(.his and .hif). if its necessary then where can i Download those files for SBC2410? --------------------------------------------------------------------------- VIVI version 0.1.4 (root@localhost.localdomain) (gcc version 2.95.3 20010315 (release)) #0.1.4 Sun Jul 2 14:14:48 EDT 2006 MMU table base address = 0x31FBC000 Succeed memory mapping. +---------------------------------------------+ | S3C2410X USB Downloader ver R1.11 SEP/03/02 | +---------------------------------------------+ FCLK=200MHz,DMA mode USB: IN_ENDPOINT:1 OUT_ENDPOINT:3 FORMAT: <ADDR(DATA):4>+<SIZE(n+10):4>+<DATA:n>+<CS:2> NAND device: Manufacture ID: 0xec, Chip ID: 0x76 (Samsung K9D1208V0M) Could not found stored vivi parameters. Use default vivi parameters. Press Return to start the LINUX/Wince now, any other key for vivi Copy linux kernel from 0x00050000 to 0x30008000, size = 0x00100000 ... done Warning: this binary is not compressed linux kernel image zImage magic = 0xffffffff Setup linux parameters at 0x30000100 linux command line is: "noinitrd root=/dev/mtdblock/0 init=/linuxrc console=ttyS0" MACH_TYPE = 193 NOW, Booting Linux......
