Hello, I try to assign the IP address to the eth0 interfaces by following command executed in /etc/init.d/rcS: udhcpc -i eth0 -s /bin/udhcpc.script Every time the IP address is obtained correctly, but sometimes (on average once every three attempts) it causes system rebooting after few seconds from console invocation. I'm pretty sure that this problem is related with udhcpc because if I comment this line in my rcS script, everything is ok. I use BusyBox v1.13.3 with Linux 2.6.29.4 kernel. Is it a known issue? Can you give any hint how to get the IP address from DHCP server and avoid system rebooting? Thank you in advance for your engagement, PS. At the end of this post, there is udhcpc.script attached. -- Piotr Piwko http://www.embedded-engineering.pl/ -----------------[begin of udhcpc.script]----------------- #!/bin/sh # udhcpc script edited by Tim Riker <Tim@Rikers.org> [ -z "$1" ] && echo "Error: should be called from udhcpc" && exit 1 RESOLV_CONF="/etc/resolv.conf" [ -n "$broadcast" ] && BROADCAST="broadcast $broadcast" [ -n "$subnet" ] && NETMASK="netmask $subnet" case "$1" in deconfig) /sbin/ifconfig $interface 0.0.0.0 ;; renew|bound) /sbin/ifconfig $interface $ip $BROADCAST $NETMASK if [ -n "$router" ] ; then while route del default gw 0.0.0.0 dev $interface 2>/dev/null ; do : done metric=0 for i in $router ; do route add default gw $i dev $interface metric $((metric++)) done fi echo -n > $RESOLV_CONF [ -n "$domain" ] && echo search $domain >> $RESOLV_CONF for i in $dns ; do echo adding dns $i echo nameserver $i >> $RESOLV_CONF done ;; esac exit 0 -----------------[end of udhcpc.script]-----------------
