Hello everyone, Anyone known how compile the SERIAL driver(smdk_serial.dll) to use all 4 ports on Tiny6410 module?. In orginal BSP the serial driver is excluded from project and after compiling the sources, driver is replaced from file files/smdk_serial.dll delivered orginal from friendlyarm (this is working with all four ports). But I need change serial driver to activate/deactivate additional pin from processor(to open transmiter RS485). Can anyone help me.? Best regards, DevPer
ALL 4 COM to use on WinCE6 tiny6410
After compiling the sources, there aren't visible COM1. In HKEY_LOCAL_MACHINE/drivers/active/#/ there are visible COM2-COM4 all records. For COM1 visible is only BusName, BusParent, InterfaceType. The method domdom to switch each other com1 TO COM2 in HKEY_LOCAL_MACHINE/drivers/builtin/serial.. is not working.
Do you want how to control the RS485? To customize the driver, please contact with mindee.friendlyarm@gmail.com mindee
I wrote myself driver and it work. But i need use all 4UART but it works with only 3. Ok i wrote email. DevPer
Hi DevPer, I did a modification in serial driver to work with a rs485 driver in wince5 for mini2440. I tried the same, but changing the ports for wince6 in mini6410 and it didn't work. Could you send me your source code? (eduardo.gabriel@ig.com.br)
