Hello, I have troubles to build CE 6.0 image on my dual-core processor PC. I have a link error (U1073) : don't know how to make sdhc_base.lib. I think that both components SDHCBASE and SDHC are build by different cores at the same times. Then SDHC can't be build because sdch_base.lib is missing. The only way I found is to disable multi processor build in manually specifying the number of processors to 1. Is there another way to force the generation of both modules on the same processor (keeping multi processor build) ? domdom
CE 6.0, build on dual core processor
I also found this. I run on a quad core, but can use only one to compile. I'm trying to get the BSP to compile in debug mode. After that i might try to look into this compile problem. I suspect that the SDHC source doesn't properly define it's dependancies or something... Thank you, Errol
I found the solution : In the file \wince600\platform\mini2440\src\drivers\sdhc\sdhc\sources, the line #SYNCHRONIZE_DRAIN=1 must be uncommented (just remove the # at the beginning of the line). It works on my dual-core, but I wonder why the line is commented... domodom
