Hello everybody, I seem to have a problem getting my mini to run reliably. My setup is: 64 MB SDRAM 256 MB NAND flash I need to reflash with factory binaries using supervivi. As linux kernel I am using zImage_A70 since I have a 7" display connected. As filesystem image I am using root_qtopia-128M_20090718.img since I am totally unable to find a 256MB Version, neither on friendlyarm.net nor somewhere else on the net. The system is bootable (from NOR) a couple times and then stops working because the kernel image has been corrupted. Now, I do not have sufficient embedded hardware knowledge to point down, why I keep getting memory corruption effects. Could anyone give me some hints on the matter? Regards, Tobi
mini2440 with 256MB NAND memory corruption
Hi, The new files for the 256MB boards are currently only available from http://arm9.net/download.asp We will upload them in the next days. Regars, Andreas
Andreas, thanks a lot. Uploading the files on friendlyarm.net would be greatly appreciated. Cheers, Tobi
hi, i have board micro2440 with nand 256MB but the link for download above is very very slow, does exist other link for download software u-boot, kernel, manual but more speed ? thanks in advance.
Unfortunately the supervivi v256 link on the arm9 hp doesn't work anymore. I would really appreciate to be able to download it here (or elsewhere)... Otherwise I'm not able to proceed working! thx
All files from the download section are up-to-date. The last supervivi-128 also supports the 256MB and 1GB boards. Rgds, Andreas
hi, thanks a lot if you can upload u-boot, zImage, uImage and root_qtopia for nand 256 micro2440. thx.
It's the same with the kernel and root images, the 128MB version also supports the bigger flashes. But I have not tested it yet. Rgds, Andreas
Hi, I have tried to install super vivi-128 in my mini2440 256 MB but hyperterminal says : NAND NOT SUPPORTED...
