Hi all, I recently bought a mini210s and a 32G TF card. According to the manual, mini210s should support 32G TF card, so as superboot210. However, after I relayout the SD card on win7, I was not able to boot the mini210s (nothing happens). I wonder if anyone can provide any info or comment on this. Regards, W
32G TF superboot with mini210s
The boot SD setup can be tricky. "fuse" the same version of superboot that you have in your images directory and OS directories. WHat was your process fro creating the bootable SD?
Just reply to myself, mini210s/superboot support 32G SD card well. My SD is a Samsung class10. To:TheRegnirps, my plan is to load a linux kernel into RAM than mount 32G SD and run init script from the mounted fs. Superboot seem to be quite good at load kernel image. So it shall work fine for me.
