Platform Type : SMDK6410
[IIC ERROR]TX Time out.
-IIC_IOControl Error Ecode=1460 (len=0)
[IIC ERROR]RX Time out.
i get this error while writing data using iic.
my code is
HANDLE hIIC;
BOOL bRet;
unsigned char iic_write_buffer = 127;
unsigned char iic_read_buffer = 0;
DWORD bytes;
DWORD dwErr;
hIIC = CreateFile (L"IIC0:", GENERIC_READ | GENERIC_WRITE,
FILE_SHARE_READ | FILE_SHARE_WRITE, NULL, OPEN_EXISTING, 0, 0);
if (hIIC == INVALID_HANDLE_VALUE) {
MessageBox(L"Unable to open i2c driver", L"Error", MB_OK);
return;
UINT32 IICClock2 = 3000;
bRet = DeviceIoControl(hIIC,IOCTL_IIC_SET_CLOCK,
&IICClock2,sizeof(UINT32),&IICClock2,sizeof(UINT32),&bytes,NULL);
UINT32 uiIICDelay = Clk_0;
if ( !DeviceIoControl(hIIC,
IOCTL_IIC_SET_DELAY,
&uiIICDelay, sizeof(UINT32),
NULL, 0,
&bytes, NULL) )
dwErr = GetLastError();
return;
IIC_IO_DESC IIC_Data;
UCHAR buff[2];
WCHAR Reg = 0x0001;
UCHAR Val = 0x11;
IIC_Data.SlaveAddress = 0x00;
IIC_Data.Data = buff;
IIC_Data.Count = 2;
buff[0] = Reg;
buff[1] = Val;
bRet = false;
bRet = DeviceIoControl(hIIC, IOCTL_IIC_WRITE,
&IIC_Data, sizeof(IIC_IO_DESC), NULL, 0, NULL, NULL);
if (!bRet)
if (dwErr == 1)
int abc = dwErr;
UCHAR StartReg = 0x0000;
PUCHAR pBuff;
IIC_IO_DESC IIC_AddressData;
IIC_AddressData.SlaveAddress = 0x01;
IIC_AddressData.Data = &StartReg;
IIC_AddressData.Count = 1;
IIC_Data.SlaveAddress = 0x01;
IIC_Data.Data = pBuff;
IIC_Data.Count = 1;
// use iocontrol to read
IOCTL_IIC_READ,
&IIC_AddressData, sizeof(IIC_IO_DESC),
&bytes, NULL);
if (!bRet)
if (dwErr == 1)
int abc = dwErr;
CloseHandle(hIIC);
using iic in wince6 for ok6410
'PUCHAR pBuff;' is not initialised ie. should be a pointer to some allocated space. Try: UCHAR Buff; and IIC_Data.Data = &Buff;
Also, you need to bit shift the slave address one to the left, also then OR with 0x01 for the read address.. eg. #define SLAVE_ADDRESS 0x01 #define SLAVE_ADDRESS_WRITE (SLAVE_ADDRESS << 1) #define SLAVE_ADDRESS_READ ((SLAVE_ADDRESS << 1) | 0x01) IIC_AddressData.SlaveAddress = SLAVE_ADDRESS_WRITE; IIC_Data.SlaveAddress = SLAVE_ADDRESS_READ; :)
