How long a time is taken Linux loading after power on MINI2440?
Time of Linux loading
With some tweaking you are able to load a custom application in about 10-15 seconds with the default kernel. there may be some more tweaking possible. The absolute user application (mini2440test) is much faster though! It takes about 2 seconds to load.
to Philipp Excuse me.You didn't understand me. I had in view itself Linux initialization(loading) as OS just after POWER ON Mini2440. Ihar
Mine takes 4 Seconds from power-on to X11/Xfbdev & xsnow running. I built it with buildroot, no special tweaks here.
neat :). Maybe this would be a good place to give out some binary so others can benefit from this fast kernel without recompiling it.
Give it a try. I run a mini2440 with 3.5" display, 256 MB Flash, vboot Bootloader. You'll probably need to build your own buildroot environment for the rootfs, too.
