Hello Everyone, So I've ran into a problem recently, and I'm not sure which route to use. I have a C# application. I want a simple database that I can remotely change values to that will, in turn, change values for the C# program. For example, I can take the information from the app, and write to XML file, excel file, or db file so that I can load it again when I power cycle it. I was thinking of using excel, that I can't use html to pull that information out and edit/update. Then came the thought of using XML. The problem is that I can't use html to edit XML remotely. For example, the two files XML and index.html are on the Mini210. I want to load up index.html and make changes to the XML file via javascript or something. I've read about this and it looks like I can't make changes remotely. I think I'm down to the SQL option, but I'm not sure about speed and everything (php, etc). Has anyone managed to remotely make changes to their C# program's values?
Server & Website CE6 C# Mini210/S
@Jean-Sebastien Breault: Thanks for your reply, but I'm not so sure of jumping into something I've never used before. I've found something that could be useful. An integrated webserver for c#; too bad it's not for compact framework. http://webserver.codeplex.com/ I think I will try to mimic their implementation. Create socket, use TCPListener, etc
