Could anybody says me: are there any usb DEVICE driver for WinCe(to create Virtual COM or for simple BULK communications , for example)? It seems that they are absent in Linux.
usb DEVICE drivers
Hi ihar, the factory default linux kernel ist very poor on compiled in USB drivers. But you can compile your own one with more driver support. I did this successful for USB audio, USB modem and USB to serial converter. The drivers self are all included in the kernel package from these web site. skip
Hi Ihar, my USB to serial converter is not a real converter, it's a short wave receiver, connected by a USB cable. Its controlled (frequency ...) by USB to serial protocol an the sound comes over USB audio. for both together, one single cable is used. My micro is host and the receiver is device.
Using Usb Host driver i connect dotmatrix printer (i.e TVS MSP-250champ) it's printing special characters.....why i resolve this issue. Please help me it's very urgent for my project.
It's possible to configure USB device (USB type B connector) to have a serial communication between the mini2440 and a PC. See SYSGEN_USBFN_SERIAL (search it in the catalog items view of Platform Builder). I didn't test this solution with mini2440 but with another Windows CE 5.0 device. domdom
I found in C:\WINCE500\PUBLIC\COMMON\OAK\CATALOG\CEC\usb.cec the line FeatureVariable ( "SYSGEN_USBFN_SERIAL", "1" ) if I set this variable to 0, USB type B connector becomes an host?
No, you must never change c:\wince600\public content.
In Platform Builder, you have to add the component \USB function
clients\Serial that you can find by searching SYSGEN_USBFN_SERIAL in the
catalog item search.
If USB Function Clients\Mass Storage is not selected, you should directly
be able to do a serial communication between the mini2440 and your PC.
In Activesync, file menu, connexion parameters (my XP is French, i
translate it, but it is certainly not the exact translation). Uncheck
"Allow USB connexion".
To access serial com on your PC, you must use the name "\\\\.\\wceusbsh001"
(example : CreateFile(TEXT("\\\\.\\wceusbsh001"), GENERIC_READ |
GENERIC_WRITE, 0 , NULL, OPEN_EXISTING, 0, NULL); )
On the mini2440, it should be comX, I don't know what is the value of X (I
didn't try on the mini2440).
domdom
ok thanks.... I have problems in managing 2 USB devices with a USB hub: the pen and a wifi VNT6656 and a multiserial FTDI chip why not work in contemporary. So I would like to use the USB type B connector to have another USB port without using a USB hub ... Maybe I'm wrong elements to insert in the catalog items. I insert these items concerning the 'usb': Asyncmac NDIS Driver (for activesync) RNDIS Client (without this item the arm can not find USB devices) Serial (for activesync) OHCI (EHCI and UHCI are not allowed) USB host support Samsung 2440A CSP something is missing or in conflict? I have to use 2 usb devices with an hub thank you very much
You can use the type B connector for activsync connexion, serial communication (see my previous post) or mass storage (the mini2440 will be seen as a USB key when connected on a PC). I don't know about problems using USB hubs. domdom
