I'm using ptxdist on my Mini2440. For some reason my boot logo just stopped working. I did not edit the kernel or file system at all! I've just been developing Qt applications. How can this happen? What is even more weird is that I have a mirror image of the exact same development system (VM) and when I load my bootloader, kernel and filesystem from that image the boot logo is still working. I compared all the settings between the working and broken development systems and all settings are exactly the same (kernelconfig and menuconfig) I even compared the console output after loading the bootloader, kernel and file system from the two development systems and they look exactly the same. I would like to resolve this without having to use the working mirror image. What can this be? What can I look for? How can I resolve it?
Boot logo suddenly not working anymore
The boologo requires CONFIG_VT=y, CONFIG_FRAMEBUFFER_CONSOLE=y and CONFIG_LOGO=y. Are you sure these settings are still valid in the binary kernel image from your *non* mirror image? Did you check the md5sums of both kernel images to check if they are really the same? Are the kernel command lines in both images are the same at runtime (check cat "/proc/cmdline")?
