[v] Download vivi
[k] Download linux kernel
[y] Download root_yaffs image
[a] Absolute User Application
[n] Download Nboot for WinCE
[l] Download WinCE boot-logo
[w] Download WinCE NK.bin
[d] Download & Run
[z] Download zImage into RAM
[g] Boot linux from RAM
[f] Format the nand flash
[b] Boot the system
[s] Set the boot parameters
[q] Goto shell of vivi
[i] Version: 1026-2K
Enter your selection: q
as you can see once ive entered my selection nothing happens.
info:
1).i use ubuntu 12.04 x64 (i did apt-get install ia32_libs)
2).i use minicom with the following :
Serial Device : /dev/ttyUSB0
Lockfile Location : /var/lock
Callin Program :
Callout Program :
Bps/Par/Bits : 115200 8N1
Hardware Flow Control : No
Software Flow Control : No
3).i connect the serial with a usb adapter.
it actually worked once and once ive entered q it said waiting for
download.
but it doesnt anymore.
please help me im stuck on this for such a long time yet its something that
is supposed to be so basic.
FriendlyARM BIOS
Right , sorry I should read more carefully. On the host have you actually got the dev node /dev/ttyUSB0 ??
well i used dmseg|grep tty and it was there if thats what you mean i also used ls-la/dev|grep ttyUSB0 and ubuntu said 180 which i think is right.
Did the mini2440 ever work for you? Are you running 12.04 on a desktop machine? By saying, "it did work once", do you mean you only managed to get a response to a <q> or that you have been available to completely load a kernel and root file system and get it to work?
both, actually but just once, and long before it broke I'm using wubi. I don't think that suddenly started to matter now
available = able ! Have you ever tried to JTAG Supervivi into the mini2440? I would guess it is more likely that Supervivi has been corrupted than your mini2440 hardware going faulty or the USB to serial adapter or Minicom running on your host. Is there someway to verify that Minicom is working, ie by talking to another computer or ? Can you check that your USB to serial adapter works on another development system? Good luck!
I've tested picocom and cutecom and they don't work either I've tested it on other computer on windows using dnw, still doesn't work I can't use jtag right now, I don't have the right port in my computer for the cable I had the idea of vivi being corrupted but when I boot qtopia from nand its terminal does the same thing, hangs after the first "enter" press i mean when it asks to activate console by enter the adapter most probably works, tested it
yes im putting the mini on nor to get to the bios menu and on nand to get to qutopia. when i put it on nor and get to the bios screen and enter an input like q to go to vivis shell as i said nothing happens i dont get the line that says waiting for download. when i put the mini on nand i see the booting on the laptop when it gets to the point of asking to press enter to activate console the same thing happens i press enter and nothing.
OK. Guess I'd be "JTAGing the NOR.pdf" http://www.andahammer.com/assets/Uploads/All2440/Firmware/JTAGingTheNOR.pdf Is there such a thing as a parallel to USB converter? Have you got the JTAG adapter board from FriendlyArm? Good luck!
ima try that and post the results here got get an adapter to usb though cuz thats pretty much all my notebook has.
i found the problem and it was the RS232 cable,replacing it would fix this problem,thanks for your help.
The mini2440 requires a null modem cable. So, your cable became faulty after your first successful attempt. There was a "theory" floating around that some times swapping the ends of the null-modem cable could make a difference. Incorrect wiring perhaps?
