Putting Entrie software stack on SD Card?
ali
hi
Is it possible to put the entire linux stack (boot loader, kernel,
filesystem) on the SD card of a mini6410 ?
is it a good idea?
have anyone done that before? if so, what's the exact procedure?
yong
i dont underestand what linux stack meant. did you mean entire source code?
or just image files of boot loader, kernel,
filesystem?
xyz
Putting the kernel root filesystem images on an SD card and booting from
on-board NAND is common.
Check out how the mini6410 boots.  I hear words like first stage bootloader
and second stage bootloader.
Happy searching!
redeagle
Yes, it is possible. I did it with linux 2.6.38 and the slackware 13.37
rootfs. But I recognized that it doesn't work with every SD-Card. I had two
8GiB SDs from the same company but just the slower one worked. And the
rootfs had to be a ext2 filesystem. ext3 also causes problems.
I described the steps I did in detail somewhere in this forum. Just search
for it in the Linux-Forum.
In short:
1. Install the FriendlyARM-Bootloader as usual on the SD-Card
2. Create new partitions but do not touch the last sectors of the SD-Card
(otherwise you destroy the bootloader)
 - the first partition has to be FAT12 with the bootload-configuration an
the kernel-image on it
 - the second partition is the ext2 rootfs
