Hello everyone, I have board mini2440 running Win CE 6.0 and I have domodom SPI driver, I'm using this driver to send 24 bytes of data via SPI channel at baud rate 12.5 MHz. Everything works fine but when I measure the sending datas, they took too much time compare to baud rate 12.5 MHz. I also attach the image that I took from oscilloscope. What could I do to send faster data? Thanks in advance and best regards, Judau
SPI Win CE driver
Hi Judau, You can increase the value of the clock till the valid extension. this will help you sending the data faster. And if this also doesn't work you can switch to SDIO interface, as the data rate will be higher than SPI.
Hello, Does anyone can use SPI DMA mode using WINCE 6.0? Can you guide me how to write driver using DMA mode for SPI? Thanks in advance, Best reagards, Judau
In what langage have you written your application ? If C# or VB.Net, you should write your application in c or c++, i wouldn't be surprized to see that your problem is here.
