I am using SJF2440 for flashing the K9F1208 Nand flash for Mini2440 board, but is very very slow. could you please let me know an alternative to this. Thanks in advance. Regards, Srinivas.
flashing to NAND
Why you are using SJF2440? put your boot switch to NOR and use supervivi menu or prompt to put anything in NAND flash. rgds Vikas
because I am not using vivi bootloader. I want to flash my own bootloader, kernel image & filesystem into Nand.
Why you are not using vivi bootloader? and if you are not using that then which bootloader u r using ?
hi, if you can use supervivi to download "u-boot" or "v-boot" or any others non-os program, you are sure to download yours bootloader too. it's very easy. regards mindee
