Hello, is it possible to "connect" an OLED display (2.8" OLED LCD Module Display C0283QGLH-T) on Mini2440 ? And if itīs possible which modifications are necessary ? (Controller Board?...) Thankīs in advance.
OLED Display
This can be connected to the Mini2440 as it also supports an RGB interface with HSYNC and VSYNC etc but you will have to write your own driver for it. You can also connect this to a databus as it has a built in driver. That would also require a driver. No need to use GPIO if your Mini2440 has a direct connect databus or just use the RGB interface with the existing LCD connections and write a suitable driver. Dave...
hi, im interested in this subject.. do you guys have any links/posts who have done this kind of job?
A quick Google came up with nothing so I suspect no one has done so. Looks like you will have to roll your own. I have not done video drivers bit as you have the drivers for the 3.5" it should be easy enough to use this as a start to your porting.! Dave...
Thanks a lot guys for your answer. I think I am not able, at the moment, to write my own graphical driver. Have you any links or help in order to start developing this kind of driver? Thanks.
