I've created a simple WinCE 6.0 .net 2.0 application with a form that fires at 10 sec interval a procedure that writes the ullAvailPhys value (available physical memory) of GlobalMemoryStatus() in a file. Basically i'm monitoring the memory load. The application doesn't do anything else, but the memory slowly but steadily decreases (it ran for a couple of hours without user interaction). Is this a normal thing? The timer is a normal system.timer, no threading involved.
Memory leak?
Hello, I'm experiencing the same problem. I cleaned the code as much as I could but still leaking. Running the same application in desktop doesn't cause leaks, and using GC.Collect periodically (just to test) doesn't solve the increase in memory usage. Using Windows.Forms timer. Did you solve the problem? Help is appreciated, thanks.
