Hi. I have some questions to ask.
I use minicom(ubuntu) with serial-usb converter and I saw bootlog on my
terminal but some time after the log show on my board's lcd panel and the
terminal does not show bootlog.
my commandline is Android-CommandLine = root=ubi0:FriendlyARM-root
ubi.mtd=2 rootfstype=ubifs
init=/linuxrc console=ttySAC0,115200 androidboot.console=s3c2410_serial0
I dont know why i cannot see bootlog in my terminal window... can u give me
any ideas?
For the kernel panic,
I copied my log which cause a kernel panic
Bluetooth: L2CAP ver 2.15
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO (Voice Link) ver 0.6
Bluetooth: SCO socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
one_wire_status: 2
VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
s3c-rtc s3c64xx-rtc: setting system clock to 2000-06-23 17:13:15 UTC
(961780395)
Freeing init memory: 1396K
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "FriendlyARM-root"
UBIFS: file system size: 2061287424 bytes (2012976 KiB, 1965 MiB, 1997
LEBs)
UBIFS: journal size: 12517376 bytes (12224 KiB, 11 MiB, 13 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
one_wire_status: 2
UBIFS: reserved for root: 0 bytes (0 KiB)
Kernel panic - not syncing: Attempted to kill init!
[<c016a9a4>] (unwind_backtrace+0x0/0xe4) from [<c050ac7c>]
(panic+0x68/0x194)
[<c050ac7c>] (panic+0x68/0x194) from [<c01827e4>] (do_exit+0x68/0x664)
[<c01827e4>] (do_exit+0x68/0x664) from [<c018310c>]
(do_group_exit+0xb0/0xe4)
[<c018310c>] (do_group_exit+0xb0/0xe4) from [<c0183150>]
(sys_exit_group+0x10/0)
one_wire_status: 2
[<c0183150>] (sys_exit_group+0x10/0x18) from [<c0165e60>]
(ret_fast_syscall+0x0)
Rebooting in 5 seconds..one_wire_status:4
arch_reset: atOK
I copied the last part..
What I did was, I built uboot, kernel, and filesystem.
built uboot, kernel work fine. However my ubi file system which built with
mkubimage rootfs_android ubi.ubi
makes that error.
The ubi image from CD works well. I compared my built ubi and CD ubi and I
found that the size are exaclty same. ( I used rootfs_android-mlc2.ubi from
CD which work fine)
Im using tiny6410 board and searched through kernel panic but i have no
clue.. can u guys help me? I alrdy wasted 4 days..
thanks,
kernel panic Attempted to kill init! ubi filesystem
Hi....Yong. As per i understand, your android command is wrong. CAn you change it to root=ubi0:FriendlyARM-root ubi.mtd=3 rootfstype=ubifs I just modified it to ubi.mtd=3 from ubi.mtd=2. Hope it works...!
