have fun:
#include "ports.h"
extern "C" {
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <errno.h>
#include <signal.h>
#include <fcntl.h>
#include <ctype.h>
#include <termios.h>
#include <sys/types.h>
#include <sys/mman.h>
#define FATAL do { fprintf(stderr, "Error at line %d, file %s
(%d)[%s]\n", __LINE__, __FILE__, errno, strerror(errno)); exit(1); }
while(0)
#define MAP_SIZE 4096UL //1000000000000UL
#define MAP_MASK (MAP_SIZE - 1) //111111111111UL
int setPin(off_t control, int shift, int state) {
int fd;
void *map_base, *virt_addr;
off_t target;
//################################################### SET PIN
//control=rGPGDAT;
if((fd = open("/dev/mem", O_RDWR | O_SYNC)) == -1) FATAL;
map_base = mmap(0, MAP_SIZE, PROT_READ | PROT_WRITE, MAP_SHARED,
fd,control & ~MAP_MASK);
if(map_base == (void *) -1) FATAL;
virt_addr = (char*)map_base + (control & MAP_MASK);
unsigned long tmp=*(unsigned long *)virt_addr;
if(state==1)tmp |= (1<<shift); //set bit "shift"
else tmp &= ~(1<<shift); //erase bit "shift"
unsigned long *va=(unsigned long *)virt_addr;
*va = tmp;//the write operation
if(munmap(map_base, MAP_SIZE) == -1) FATAL;
close(fd);
return true;
unsigned long readReg(off_t control) {//read whole register
int fd;
off_t target;
close(fd);
//read_result = *((unsigned long *) virt_addr);
return tmp;
int readPin(off_t control,int shift) {//read PIN
int fd;
off_t target;
unsigned long mask=0;
close(fd);
mask |= (1<<shift);
if(tmp&mask) return 1;
else return 0;
ports.h
#ifndef __2440ADDR_H__
#define __2440ADDR_H__
// UART
#define rULCON0 0x50000000 //UART 0 Line control
#define rUCON0 0x50000004 //UART 0 Control
#define rUFCON0 0x50000008 //UART 0 FIFO control
#define rUMCON0 0x5000000c //UART 0 Modem control
#define rUTRSTAT0 0x50000010 //UART 0 Tx/Rx status
#define rUERSTAT0 0x50000014 //UART 0 Rx error status
#define rUFSTAT0 0x50000018 //UART 0 FIFO status
#define rUMSTAT0 0x5000001c //UART 0 Modem status
#define rUBRDIV0 0x50000028 //UART 0 Baud rate divisor
#define rULCON1 0x50004000 //UART 1 Line control
#define rUCON1 0x50004004 //UART 1 Control
#define rUFCON1 0x50004008 //UART 1 FIFO control
#define rUMCON1 0x5000400c //UART 1 Modem control
#define rUTRSTAT1 0x50004010 //UART 1 Tx/Rx status
#define rUERSTAT1 0x50004014 //UART 1 Rx error status
#define rUFSTAT1 0x50004018 //UART 1 FIFO status
#define rUMSTAT1 0x5000401c //UART 1 Modem status
#define rUBRDIV1 0x50004028 //UART 1 Baud rate divisor
#define rULCON2 0x50008000 //UART 2 Line control
#define rUCON2 0x50008004 //UART 2 Control
#define rUFCON2 0x50008008 //UART 2 FIFO control
#define rUMCON2 0x5000800c //UART 2 Modem control
#define rUTRSTAT2 0x50008010 //UART 2 Tx/Rx status
#define rUERSTAT2 0x50008014 //UART 2 Rx error status
#define rUFSTAT2 0x50008018 //UART 2 FIFO status
#define rUMSTAT2 0x5000801c //UART 2 Modem status
#define rUBRDIV2 0x50008028 //UART 2 Baud rate divisor
// I/O PORT
#define rGPACON 0x56000000 //Port A control
#define rGPADAT 0x56000004 //Port A data
#define rGPBCON 0x56000010 //Port B control
#define rGPBDAT 0x56000014 //Port B data
#define rGPBUP 0x56000018 //Pull-up control B
#define rGPCCON 0x56000020 //Port C control
#define rGPCDAT 0x56000024 //Port C data
#define rGPCUP 0x56000028 //Pull-up control C
#define rGPDCON 0x56000030 //Port D control
#define rGPDDAT 0x56000034 //Port D data
#define rGPDUP 0x56000038 //Pull-up control D
#define rGPECON 0x56000040 //Port E control
#define rGPEDAT 0x56000044 //Port E data
#define rGPEUP 0x56000048 //Pull-up control E
#define rGPFCON 0x56000050 //Port F control
#define rGPFDAT 0x56000054 //Port F data
#define rGPFUP 0x56000058 //Pull-up control F
#define rGPGCON 0x56000060 //Port G control
#define rGPGDAT 0x56000064 //Port G data
#define rGPGUP 0x56000068 //Pull-up control G
#define rGPHCON 0x56000070 //Port H control
#define rGPHDAT 0x56000074 //Port H data
#define rGPHUP 0x56000078 //Pull-up control H
#define rGPJCON 0x560000d0 //Port J control
#define rGPJDAT 0x560000d4 //Port J data
#define rGPJUP 0x560000d8 //Pull-up control J
#endif //__2440ADDR_H__
Accessing Registers from USERLAND! (C/C++)
What board is it for? I tried similar access to registers at Mini6410, there are no errors, but the values are written through /dev/mem, reading back gives the old ones. I'm using the Samsung kernel 2.6.38. Thanks for ideas.
I don't think the 6410 was available back then. #ifndef __2440ADDR_H__ tends to suggest the mini2440
