Hello, I'm facing a problem. The problem is with the start of the CE 6.0 image. With the DNW by pressing the 'w' an image of winCE is uploaded on my mini2440 and the image is succesfully run, seeing the desktop and is fully functional. But when i restart the mini so that the image loads automatically it is stuck. I did this: copied the supervivi-128 with DNW(ofcourse from the BSP 6.0 folder); copied the Nboot_t35.bin (also the correct one for my mini); copied the NK.bin that started fine; but after restarting my mini nothing happens. DNW shows: load Windows CE Image.. no logo picture and gets stuck... What could be the problem or if anybody had the same problem ? Thanks in advance, b
CE 6.0 image runs only when uploading with DNW
hi you must update the NOR flash's bios with the new supervivi-128M you can use H-JTAG to do that. regards mindee.
Hello, Thanks for the fast reply! Yea it really seems that something needs to be updated.. I'll try to update it as soon i get out from work. Thanks again and good day, b
Hi, I am a newbee, have same problem, would you be kind enough to guide how to update the NOR flash bios. Thank you max
Hi Max, Here's an nice guide; http://www.andahammer.com/assets/Uploads/All2440/Firmware/JTAGingTheNOR.pdf And the new supervivi can be found in the BSP; http://www.friendlyarm.net/dl.php?file=wince6-bsp_20100106.zip
When you are using a newer version of H-JTAG have a look here: http://www.friendlyarm.net/dl.php?file=download.pdf
