I noticed today that the DM9000 NIC stops passing traffic when trying to transfer a large amount of data over it. I have 3 of these boards, happens on all 3, so it sounds like a hardware problem and not just related to one board. (2 boards were purchased at the same time, came with latest software, the original board came with older software, so all 3 were definitely not from the same batch). In any event, one way to test this out, see if it happens for you (I'd be interested in hearing if it does) -- create a large file, let's say 20 MB. Fire up an FTP server on another computer, console in or telnet into the board, fire up an ftp session to that server, do a get on that file and store it locally in /dev/shm/ so you're not writing to flash (though it doesn't matter writing to flash or memory, same problem). It's spurratic, sometimes it stops passing traffic around 3.5 MB, sometimes at 10 MB, sometimes at 150 KB. Random every time. Only way to get it to pass traffic again is a hard reset of the board. I have tried dropping the MTU on the board down, to no effect, still has the same behaviour. Tried dropping the MTU on the switch down for that port, again to no effect. Anyone else seeing this problem?
DM9000 stops passing traffic
There was something like this related to 2.6.29, have you upgraded to something later? Think it is mentioned on buserrors's site http://bliterness.blogspot.com/ in the archives.
Another thing MTU? Is that the Boa web server? I have the impression that terminating the server or re-booting from the application in Qtopia (on the factory install) have no effect. Dave
I purged Qtopia from my image a long time ago. MTU is the Maximum Transmission Unit (the maximum size of a packet a network device can send. 1500 is standard on fast ethernet networks). I'm running 2.6.29.2 on the device, I'll try upgrading it to 2.6.29.4 and see if that helps in the next few days. Right now to get my big files over (firmware images) i'm using the SD card or a USB flash drive.
I am experiencing exactly the same problem under WinCE 5.0 Posted my problem here (http://friendlyarm.net/forum/topic/34), but no answer yet.
I cannot answer to WinCE unfortunately, however upgrading to the linux kernel 2.6.29.4 resolved my issue.
Just curious why you didn't go to 2.6.30.3 as I am tossing around whether or not to upgrade from the factory version. Do people generally only upgrade to fix problems or what are the criteria? Cheers, Dave
I had problems with 2.6.30.3 decompressing the kernel and just locking up, so I went down to 2.6.29.4 and no problems. As a general rule, I don't upgrade the kernel on anything unless there's a real need to. I.e., to fix a driver, security hole, or if there's a feature I would like or need that is only present (or working) in a newer version.
Just a long shot on decompressing issues: http://www.friendlyarm.org/topic.asp?TOPIC_ID=42&SearchTerms=decompress Thanks for the pointers on "to upgrade or not to upgrade". Glad to hear you finally got the other issues sorted out. Looks like some good tutorial material there. Dave
Yeah I had already started looking into replacing the toolchain. Just let everything build overnight, I'm replacing (not just modifying) the default image today, building everything against the new toolchain. Hope all goes well.
I have the same problem with yours wherein every time I load a files my network connection always disconnected and I have to reboot the system. I'm using kernel 2.6.29.0 and I want to upgrade to 2.6.29.4 or .6. Please let me know how to upgrade the kernel and which directory have put the untared file. Thanks, Puma
