Hi Friends,
I have tiny 6410 and i tried to install Android and Wince but its not
getting installed..
1.First I formatted my SD card using SD flasher.
2.Then I copied Image file for Wince into SD card.
3.In that i select friendly arm.ini file and i changed OS=CE6 and
action=INSTALL,Status Type = Beeper| LED.
4.After that i inserted SD card and Selected SD boot mode then i gave
power to the board.
But i didn't get any changes in my kit and LCD,Actually i selected beep
and led but That also not performing.The power button only getting glow,
please help me to make that kit work there is any other possible way to
installed the OS in to tiny 6410.
When I connected Serial cable to COM0 and i selected nand flash that time
hyper terminal window is continuously getting Reset.
Installing wince to Tiny 6410 problem
Hyper terminal is a.... windows application:-) Do you have a Linux machine to connect the serial cable and run minicom -s -o -w (setup your com port, disable flow control (press F), press esc) and power up the Mini. As a try:-)
vinodh i installed linux use sdcard as you say: format sd card using sd flasher note path of sdcard that is important because i lost long time i see that [root@FriendlyARM /]# cd sdcard/ [root@FriendlyARM /sdcard]# ls LOST.DIR images [root@FriendlyARM /sdcard]# cd images/ [root@FriendlyARM images]# ls Android Linux FriendlyARM.ini superboot-6410.bin [root@FriendlyARM images]# ls -al drwxrwxrwx 4 root root 4096 Apr 15 2012 . drwxrwxrwx 5 root root 4096 Jan 1 1970 .. drwxrwxrwx 2 root root 4096 Apr 15 2012 Android -rwxrwxrwx 1 root root 1655 Apr 15 2012 FriendlyARM.ini drwxrwxrwx 2 root root 4096 Apr 15 2012 Linux -rwxrwxrwx 1 root root 270336 Nov 16 2011 superboot-6410.bin you only copy on folder as i indicate . after that chose init by sdcard and reboot. i is not good english .perhap only this way can be show my ideal holpe can help you .
