Hi all, there seems to a problem with my Mini2440. Downloading the kernel and the qtopia image is no problem but I can't boot the systems afterwards. The systems reports lots of bad blocks and bad erase blocks and ends with yaffs_read_super: isCheckpointed 0 VFS: Mounted root (yaffs filesystem) on device 31:3. Freeing init memory: 128K Warning: unable to open an initial console. Failed to execute /linuxrc. Attempting defaults... Kernel panic - not syncing: No init found. Try passing init= option to kernel. What is wrong? Regards Peter
Boot problems
Hi Andreas, thanks for your reply. I use a 3.8 A switching power supply. My board did well with this power supply. Then I tried to load some other operating systems ...... Regards, Peter
Yes, at least I hope so. I used zImage_T35 and root_qtopia-64M_20090429.img. Correct? Regards, Peter
My 2440 has 64MB, but I have tried with the 128 MB versions of the software as well and without success. I have done the following: - Format NAND flash for Linux - Download Linux Kernel (using file zImage_T35, no extension like bin) - Download root_yaffs image (using file root_qtopia-64M_20090429.img) - Boot the system All I get is a Tasmanian Devil on the LCD and (beneath lots of other messages) . . . Bad eraseblock 419 at 0x000003460000 Bad eraseblock 420 at 0x000003480000 Bad eraseblock 421 at 0x0000034a0000 Bad eraseblock 422 at 0x0000034c0000 Bad eraseblock 423 at 0x0000034e0000 Bad eraseblock 424 at 0x000003500000 Bad eraseblock 425 at 0x000003520000 Creating 4 MTD partitions on "NAND 256MiB 3,3V 8-bit": 0x000000000000-0x000000060000 : "supervivi" 0x000000060000-0x000000260000 : "Kernel" 0x000000260000-0x000040260000 : "root" mtd: partition "root" extends beyond the end of device "NAND 256MiB 3,3V 8-bit" -- size truncated to 0xfda0000 0x000000000000-0x000040000000 : "nand" mtd: partition "nand" extends beyond the end of device "NAND 256MiB 3,3V 8-bit" -- size truncated to 0x10000000 and . . . block 424 is bad block 425 is bad block 426 is bad Partially written block 152 detected Partially written block 152 detected Partially written block 152 detected Partially written block 152 detected Partially written block 152 detected Partially written block 152 detected yaffs_read_super: isCheckpointed 0 VFS: Mounted root (yaffs filesystem) on device 31:3. Freeing init memory: 128K Warning: unable to open an initial console. Failed to execute /linuxrc. Attempting defaults... Kernel panic - not syncing: No init found. Try passing init= option to kernel. NAND is reported as 256 MB by the system. What could be wrong? Should I provide the complete log of the booting process? Regards Peter
If the system reports 256M NAND I would suspect that either it really was 256M or there is another problem. How old is the dev board? Was it sold as 64M? Can you read the part number on the flash chip?
The board is brand new, at least I have bought it a few days ago. I thought it is a 64 MB NAND board, but in fact it was sold as a 256 MB NAND board. The NAND is a Samsung K9F2G08U0B. Peter
Thanks for this information. Having 256 MB NAND is fine, if the board will boot again. And now? There seem to be no 256 MB images/versions. Is creating a partions with a total capacity of 128 MB a solution? Peter
The files for the new boards (256MB, 1GB) are currently only available at: http://arm9.net/download.asp We will upload them to this site this weekend. Regards, Andreas
Well, it almost did the trick. I can load and start Qtiopia and Android now, but both OS don't start by themselves. I have to boot them via the boot command in DNW or vivi. Do I have to set a boot flag or something like it? Peter
