Hi, my 1 wire toutch stops to work or display don't turn on after some hours idle, CPU still working, I can access disk's over USB from my PC. After rebooting displays and touch works OK/ Any Idee what the reason can be? Does someone have the source for touch_1wire.dll need to add debug output to be able to locate the problem. Anders
touch_1wire
I have connected a mouse to to my mini6410 and it seems that the touch is working but the screen back light don't turn on. I have set the screen backlight to turn off after 30 seconds. If I leave the sysem with the screen off for more than aprox 2 hours the screen backlight never turns on again. Regardless if I moves the mouse or touching the screen. If I leave the screen backlight on the sysem works for days. Any one who has a clue what the reason could be? Or how to debug? Anders
After some more investigation I have notice that the touch and the backlight controll stops to work after some hours. When I enter the backlight control settnings in the setup and activate the timeout it will not longer do any timeout and the brightness in advanced setting don't change the backligit when I move the bar. Is there any connection between the touch display and the backlight control? Does any know from which driver the backlight control is controlled? Anders
