hello friends, can someone please tel me the detailed procedure and code for interfacing an LED and a temperature sensor (prefarably LM35) to the mini 2440 board. i am in urgent need of this guys. so please please help me...please !
interfacing an LED and a temperature sensor to mini2440
Read the schematics coming with the Mini2440 and you will know how to connect a LED and an I2C device to it.
LM35 10mv/degree C, even at 150C you will only get 1.5Volts out of it, which will be safe to apply directly to one of the spare ADC inputs, AIN1, AIN2 or AIN3. If you have enabled ADC in the kernel, all you need to do is cd your way to /sys/devices/platform/s3c24xx-adc/s3c-hwmon and do a cat in0_input (if you chose AIN1) Or just use the mini2440 BSP at Pengutronix and get that assignment in on time.
Thanks davef, now I see a LM35 is not like a LM75 (all these numbers...). @pavan: forget my hint about I2C.
Hi Pavan, I got the way to interface four leds on mini2440 board, you can come here to have a look: http://mini2440vietnam.blogspot.com/2012/06/control-leds-on-mini2440-by-...
