I have Android 2.3.4 running on a Mini6410 and after I first boot up I can select the WiFi and using the SDIO WiFi module I can connect to the network. Web and applications etc work with this to connect to the internet. If I shutdown the board and reboot, the WiFi does not restart. It is enabled in the settings but it won't auto connect until I select the access point again. It shows that the access poiint is rememebered so it has the Password etc. How can I get the Mini6410 to reconnect on boot up? I need this to allow my application to talk to a PC server on the network. Thanks Dave... PS.. It does the exact same with the Mini210 so this must be a configuration issue.
