Hi all I am new to using the ARM9. I am trying to establish serial communication between my mini2440 and a atmega328. I have programmed the atmega 328 to switch on a LED when it recieves a 'H' over serial. This program runs well when the 'H' is sent from my pc... but i cant manage to do it from the mini2440... what should i do... any help appreciated. Cheers Chinmay
Interfacing ARM9 with external hardware
Hi Chinmay Duvedi, What serial port on mini2440 do you use ? Check if the COM configuration (buadrate, stop bits, etc) is the same for both devices. Try to send a character from mini2440 to PC. Regards, azzido
