Hi I just had to replace mini2440 t35 LCD, with some new available w35 one. The LCD driving via modification of mach-mini2440.c and mini2440_config files was successful, but it seems that touchscreen has rotated 180 degree so when I touch left side, cursor goes righ side and when toch up side, curso goes down side. where is the problem? what files should be modified?
rotate touch screen
You need a new calibration if you changed the geometry of your screen. run the tool "ts_calibrate" again
sorry, About 1/3 of right side of screen, shows only vertical colored lines. I checked lcd flat cable and reinstalled it, but the problem till exist. It seems, till there is problem with LCD driver. what other files (except mach-mini2440.c and mini2440_config) must be manipulated for driving w35 ?
I have just come across this problem. Did you manage to solve it? If so, would you please tell me how!
