Hello, I downloaded U-Boot sources and intended to study/modify it a bit for my own needs. However, I cannot find sources for the binary blob board/samsung/mini6410/nand_6410.fo provided in the archive. According to the GPL under which U-Boot is licenced, sources for this file should be available. Is there a link somewhere for them? Thanks.
Sources for nand_6410.fo in U-Boot
i think the boot loader ( u-boot ) that comes with mini6410 have some problems with me and i used superboot-6410 to solve this problem instead of them until i will try to compile u-boot with my own and try it again :)
The U-Boot provided by FriendlyARM works for me, at least for simple operations. However NAND operations (for MLC2 NANDs at least)... not so well. I intended to implement some custom commands and add support some U-Boot commands disabled in FriendlyARM's U-Boot, but without the source code for the NAND part, I'm stuck. :(
