Hello all, I had purchased A LCD-VGA adapter.(type LCD2VGA ) I had also load the VGA image(given in the DVD in pack) in mini6410 board. But after booting nothing works. (My monitor keeps searching for signals). What should i need to do? where is the problem? Where can i found the documentation for that hardware? Please guide me. Thanks in advance.
LCD to VGA problem
hello all, can anybody guide me to overcome the problem? Searched a lot but not got anything relevant. Thanks in Advance.
Hello all, Still fighting with the same issue. If Connected to LG Monitor it gives me following error: Out of frequency HF - 56.5 Khzs VF - 70.0 Hz Operating Frequency HF - 30 to 54 Khzs VF - 50 to 120 Hz waiting for valuable suggestions.
There are two VGA adapters. The LCD to VGA for the Mini2440 and the EZVGA for 6410 and 210. Can you post a link to the one you are trying to use?
Hello, http://www.friendlyarm.net/sites/products/lcd2vga_1.jpg I am using the VGA adapter shown in the above link.
That board is for Mini2440. I have never seen it used with the Mini6410. It mounts in the holes where a 3.5" LCD would go. The EZVGA works on 6410 and is much less expensive. http://andahammer.com/ezvga/
hi, I tried LDC2VGA which I have with my OS, and it worked fine. And yes, the size is not compatible with mini6410 but managed somehow. thanks for your response. Sumeet Thakre.
hi all, i have a LCD to VGA adapter and i have a problem when i connect this to the TV with reference 42LE4600 the TV if the recognizes but the problem is that not seen in this good, do see a box white with lines that cross vertically the screen. Thanks in Advance.
Hello Jonathan, Did you load the image for LCD? Please check the resolution of your TV. It might be different than your loaded image.
