I want to add a program autorun at startup and skip the explorer window. what i have to do for that.I also checked MS forums and it is written that for to run in autorun edit reg of ce5 in init and add launchxx,& dependxx. I do the same but it was not work for me.sorry for my poor english.please help me...?
Autorun of program at startup
thank you sir,for your help & consideration.i succeded for autorun.my mistake is that i copy the exe file to sd card in 2440 board,and try for autorun.i got the result when i copy the exe file to resident flash.again thank u.
Hai markpq, after switch on mini2440 board,go to my computer,in the explorer one drive is there.put ur exe file on this drive by copying,and do all other things as mentioned by Andreas Watterott.that means edit the reg init and add launchxx,& dependxx.thank u.
hi sreekanth! thank for your help! do you edit the reg init before build OS image or after load on mini2440 board? I don't know where to put my exe on OS image!
we can put exe at any location in flash drive.only thing is that the path is to be correctly on reg.for ex RESIDENT FLASH/NEW FOLDER/XX.EXE
