Hi Gentlemen, I met one problem need your help to solve it. I base on reference design circuit to make an evaluation board, but removed some functions that I don't need (such as like WiFi, Camera, Audio), basically, the evaluation board can work normal, excpet SD function. I found my evaluation board can't boot from SD card, I have checked my SD card by PC and 6410 EVK (bought from Arm9Home), the SD card can work normal as no problem. I have also compared circuit design with reference circuit, but I can't find any difference. Can anybody help me to solve this problem. I'm much appreciating for your any help. Thanks. Best regards, Joseph
6410 can't boot from SD Card
insert the SD card in your pc and open SD falsher.exe on xp or run it as Administrator on win7 or win8 and then format is and browse superBoot-6410.bin then make fuse it will make two partitions 130 M which will be disappear and the still with the name FRINDLYARM go inside it and make new folder (rename it to images ) and go inside it again and put ARMFRINDLY.ini and the SuperBoot-6410.bin and make another folder inside images and rename it to linux and put inside it 1) zImage_n43 or your zImage 2) rootfs_qtopia_qt4.ext3 if you will run it only 3) rootfs_qtopia_qt4.img if you will install go back and edit the ARMFRINDLY.ini as #This line cannot be removed. by FriendlyARM(www.arm9.net) LCD-Mode = Yes LCD-Type = N43 CheckOneButton=No Action=install OS= Linux VerifyNandWrite=No StatusType = Beeper| LED #################### Linux ##################### Linux-BootLoader = superboot-6410.bin Linux-Kernel = Linux/zImage_n43 Linux-CommandLine = root=/dev/mtdblock2 rootfstype=yaffs2 init=/linuxrc console=ttySAC0,115200 Linux-RootFs-InstallImage = Linux/rootfs_qtopia_qt4.img Linux-RootFs-RunImage = Linux/rootfs_qtopia_qt4.ext3 ***************** then insert SDcard into your arm kit and push the left button to s2 to boot from SDcard and use the second left button to go down and use the right above one to select and then the instalation will begin at the end return the left button to boot from amr mini6410 i hope i could help you :)
