Morning. So I was up late trying to figure this out... I just got a MINI2440 with a 3.5" LCD (this one: http://www.andahammer.com/mini35-sdk/ ). Most of the images I use do not display correctly on the LCD. I use the T35 images (linux and Win) - right?, and, looking at the screen in portrait orientation, the image... well, here's a link to a picture for your viewing pleasure: http://oi39.tinypic.com/102rqep.jpg That happens with the T35 images I have... using a W35 image works as far as the image is in the right orientation, but it's shifted by ~10pixels, which, from my reading, means I should be using a T35 image to get the correct margins, but that results in the above. SO, what am I doing wrong? Is it as simple as some sort of boot parameter, hardware fault, or otherwise? Thanks for the help! - Josh
LCD Image Usually cut off...
UPDATE: So, I took the LCD off of the mounts, and on the back: "W35i"... Makes more sense now. Now... to get Win CE6 working...
