My mini2440 got hung up during when I switched it on. During troubleshooting I found that, one of my wire of Power Supply Connector was removed. after re-soldering, now it does not start at all, only Linux main screen ( with the baby penguin ) and down at the screen cursor keeps on blinking. Also, I shorted two wires at Adopter end connector since, in the kit those two terminals are shorted. does this create problem?
Problem during Loading
Get minicom running on the host and using the serial cable watch the messages during boot-up. It appears to be getting quite away through the boot process. I don't understand the last question. Which cable are you referring to?
Sorry, I was assuming your were using Linux. If you are using Windows get DNW running and watch the messages.
