Hi Guys, I have a EM2440-III board which is exactly same as mini2440 except it has only 4 buttons instead of 8 as on mini2440. 2 of them are also connected to different IRQ's. By mistake i corrupted U-boot and the kernel on the board hence I programmed vivi from friendly arm website into the NOR flash using H-Jtag software. Now the boards boots with vivi from NOR flash. I am trying to dowload u-boot as per the following links. http://narnia.cs.ttu.edu/drupal/node/131 http://bill.station51.net/index.php?post/2010/01/16/U-Boot-on-Mini2440 After I run "load ram 0x32000000 <uboot size> u-boot" command in vivi shell. I get an error message "USB host is not connected yet". I also tried ./s3c2410_boot_usb but this gave me an error "Cannot find QT2410 device in bootloader mode" I tried installing the same thing with dnw software in windows 7 64bit but there also I get the same usb error. Even tried installing usb-downloaddr-setup but no luck. The board doesnt boot at all -------------------------------------------------------------------------- Enter your selection: b Copy linux kernel from 0x00060000 to 0x30008000, size = 0x00500000 ... done Warning: this binary is not compressed linux kernel image zImage magic = 0xffffffff Setup linux parameters at 0x30000100 linux command line is: "noinitrd root=/dev/mtdblock3 init=/linuxrc console=ttySAC0" MACH_TYPE = 1999 NOW, Booting Linux...... -------------------------------------------------------------------------- Nothing happens after this. Can some one please give some pointers to solve this issue. Is there any way to program u-boot by some other means? Cheers Tama
USB host is not connected after flashing vivi throught JTAG
> After I run "load ram 0x32000000 <uboot size> u-boot" command in vivi > shell. But, the command is "load ram 0x31000000 <uboot size> u"
Hi Davef, The board has got 64MB Nand Flash (K9F1208UDC), 2KB or NOR Flash and 64MB SDRAM. Today I tried to flash MINI2440 U-boot "u-boot-v132.bin" directly onto NOR Flash and U-boot from EM2440III SDK cd onto NAND Flash. When I boot from Nor flash with Mini2440 U-boot the board dosent gets recognized by windows on USB port. So I issue usb start command, but then also it is not detected by windows. If I boot from NAND flash with U-boot(from EM2440SDK) the board gets recognized as SEC S3C2410X TEST B/D. I dont have the drivers for this hence I cannot communicate with the board. Has any one experience similar situation. Could some one please give some pointers. Cheers Tama
Ah, you have two boards with two different problems. I have never heard of or tried putting u-boot in NOR. Following that tutorial in your first link and all the work I have done using the Pengutronix BSP ... Supervivi remains in NOR and then you put the bootloader in NAND. What instructions or tutorial are you following to place u-boot in NOR?
And you have read all relevant threads here: http://billforums.station51.net/viewforum.php?f=1&sid=6e7c3ad3afdccb...
Hi Davef, I have only one board (EM2440III). As mentioned earlier this board is exactly same as Mini2440. Hence I want to flash this board with uboot, linux kernel and root fs from mini2440. Today I programmed NOR flash on the board with supervivi 2010-08-18 from friendly arm download link. Then I boot the board from nor flash. I can see ##### FriendlyARM BIOS for 2440 ##### from super vivi. Then i pressed q to switch to vivi prompt. load ram 0x31000000 239016 u Then I get an error message saying USH host not connected. As per the link http://narnia.cs.ttu.edu/drupal/node/131 It says USB host is connected. But In my case it is saying usb not connected. I tried all these steps on xp machine. I couldnt even see a unknow usb device in windows device manager. Looks vivi dosent have usb drivers. So I programmed uboot 2010-07-01(friendly) on to NAND flash using Hjtag tool. After I boot from NAND flash I boot can see --------------------------------- USB: S3C2410 USB Deviced In: serial Out: serial Err: serial MAC: 08:08:11:18:12:27 Hit any key to stop autoboot: 0 --------------------------------- In this case also no USB activity on the PC. Apart from sdcard can download the kernel and file system through USB when I boot from NAND flash to uboot. Cheers tama
There are some drivers for DNW, have you got those?
On the downloads page:
Software
Mini2440 / Micro2440
USB download driver setup
USB download driver (inf)
DNW download tool (Windows)
I recall that I had to get the sequence right, ie start DNW then plug USB
cable to the mini2440 in OR the other way around.
I assume your board has a USB host connector?
The 64M NAND boards require the supervivi-64 version and the 64M version of u-boot (latest u-boot versions auto-detect I think). The block read and write sizes are different for 64M versus all larger NAND.
I programmed NOR flash again with supervivi-64 through jtag. Then after I boot from Nor flash and try to dowload u-boot, I get the same error USB host not connected. I even tried xmodem but that is also not working. I dont understand what is causing this error. I even tried on a linux machine. My biggest problem is that after I program nor flash with supervivi I am not able to go the next step of dowloading uboot. Any other means to load u-boot.
Yes I tried with DNW and even with supervivi full download tool. I though there was something worng with my board. Hence I borrowed my colleagues mini2440 with 3.5 inch lcd and tried the same steps on it. Even with mini2440(3.5lcd) i was getting same results. Supervivi which is on the board doesnt connect on USB. I tried this on a xp machine and reinstalled all the usb drivers also. But still no luck. I have attached circuit diagram for my board em2440.
So, now you have two non-functional boards? Has your colleague ever been able to use Supervivi on his host system? Did he ever JTAG in Supervivi to get his board working again? Are you following the guide called "Mini2440 Downloader Instructions"? I just found another description of the "proper" sequence I used: - run DNW - switch to NOR - power on the mini2440 - you should see the user menu in DNW and - THEN plug in the USB cable from FriendlyArm to the PC Don't think the schematics are going to tell anyone what is wrong. Get the mini2440 working again and then maybe you have go to a forum which is deals with the em2440 or the manufacturer. Good luck.
The board which I borrowed from my colleague (mini2440 3.5inhc LCD) is working. The board boots as it has factory bootload and other images. I just got that board to test whether after booting from nor flash into supervivi usb is detected. But apparently when i hit q in super vivi and say load ram <addr> <file size> u. It says USB host not connected. This is exactly the same thing happening on my board. I check the usb schematic everything is identical. One more question, when the procedure says USB host its the Mini2440 -> USB Type A connector on the board -> Type A-A cable -> PC. or is it mini2440 type B - Type B- Type A cable -> PC
I just found a link to similar thread in WindowsCE section. This guy is also facing the same problem as I am. http://www.friendlyarm.net/forum/topic/2257
You could try both ways! The square cable goes into the mini2440 and the flatter rectangular end goes into the PC.
Finally after trying for so many days I could get supervivi to talk through USB. There is something wrong with supervivi_64MB USB. After reading the thread "http://www.friendlyarm.net/forum/topic/2257", I downloaded supervivi_128MB onto NOR flash. After booting USB started working and I could download U-boot. I might change the NAND chip on the board. Any idea what is the 128MB/256MB/1GB nand chips number which is being used on mini2440 boards. Cheers
But, you said early in the thread that it was a 64M flash. Why change the NAND chip? If it REALLY is a 128M flash why not keep it? Read the number off the NAND chip and go and download the datasheet off the downloads page!
The existing flash which came along with the board is 64Mb. Initially I downloaded supervivi_64mb but the USB didn't work. Then after reading the other thread which I mentioned earlier. That guy has same board as I have with 64mb nand + 64mb sdram. So i tried uploading supervivi_128mb. After booting from NOR with supervivi_128mb USB started working. Hence i mentioned I can change that NAND flash from 64MB to 128MB.
> Hence i mentioned I can change that NAND flash from 64MB to 128MB. You mean in some menu selection, not actually physically replacing it ... right? I thought you were saying you were going to physically replace the chip :) Well, if everything else works properly you have managed to solve it. Good luck.
No I was planing to change the physical 64MB nand chip to 128MB nand chip. Does it make any difference if I download superviv_128MB, but physically nand chip is only 64MB. I have been trying different methods to upload kernel and rootfs on the board but no success. I could manage to compile kernel and convert zimage to uimage. But when no success with building a rootfs. I even followed http://code.google.com/p/friendlyarm/wiki/Linux_Tutorial but the links what are there for copying etc from existing rootjffs2 dosent work. I even read your thread about uploading files via tftp. Could you please give some inputs on this. cheers
Hi Davef, Could you please give some inputs on compiling rootfs and uploading the roofts + kernel to the board. I downloaded busybox1.13.4 and followed this link to compile rootfs "http://wiki.iface.ch/index.php/Basic_rootfs_for_Mini2440". There were no errors with compiling the rootfs apart from a warning. -------------------------------------------------- You will probably need to make your busybox binary setuid root to ensure all configured applets will work properly. -------------------------------------------------- After that I created all the folders and files as per the link "http://wiki.iface.ch/index.php/Basic_rootfs_for_Mini2440". But How do i tar/mount this file system. What kind of file system is this. I am able to compile kernel and then convert it into uImage. then I followed this thread to upload via tftp http://billforums.station51.net/viewtopic.php?f=1&t=205 "tftp 30008000 uImage.bin" then issue "bootm 0x30008000" ------------------------------------------------------------- U-Boot 1.3.2-mini2440 (May 25 2010 - 19:15:21) I2C: ready DRAM: 64 MB Flash: 2 MB NAND: 64 MiB Found Environment offset in OOB.. USB: S3C2410 USB Deviced In: serial Out: serial Err11:18:12:27 MINI2440 # MINI2440 # printenv bootdelay=3 baudrate=115200 ethaddr=08:08:11:18:12:27 netmask=255.255.255.0 usbtty=cdc_acm mini2440=mini2440=0tb bootargs_base=console=ttySAC0,115200 noinitrd bootargs_init=init=/sbin/init root_nand=root=/dev/mtdblock3 rootfstype=jffs2 root_mmc=root=/dev/mmcblk0p2 rootdelay=2 root_nfs=/mnt/nfs set_root_nfs=setenv root_nfs root=/dev/nfs rw nfsroot=${serverip}:${root_nfs} ifconfig_static=run setenv ifconfig ip=${ipaddr}:${serverip}::${netmask}:mini2440:eth0 ifconfig_dhcp=run setenv ifconfig ip=dhcp ifconfig=ip=dhcp set_bootargs_mmc=setenv bootargs ${bootargs_base} ${bootargs_init} ${mini2440} ${root_mmc} set_bootargs_nand=setenv bootargs ${bootargs_base} ${bootargs_init} ${mini2440} ${root_nand} set_bootargs_nfs=run set_root_nfs; setenv bootargs ${bootargs_base} ${bootargs_init} ${mini2440} ${root_nfs} ${ifconfig} mtdids=nand0=mini2440-nand mtdparts=mtdparts=mini2440-nand:0x00040000(u-boot),0x00020000(u-boot_env),0x0050 0000(kernel),0x03aa0000(r.4 serverip=192.168.1.6 partition=nand0,0 mtddevnum=0 mtddevname=u-boot Environment size: 1051/131068 bytes MINI2440 # tftp 0x32000000 uImage dm9000 i/o: 0x20000300, id: 0x90000a46 DM9000: running in 16 bit mode MAC: 08:08:11:18:12:27 TFTP from server 192.168.1.6; our IP address is 192.168.1.4 Filename 'uImage'. Load address: 0x32000000 Loading: *T ###################################T ############################## ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ##################################################### done Bytes transferred = 2266656 (229620 hex) ------------------------------------------------------------------------- then I write the kernel to nand flash using following command "nand write 0x32000000 kernel" NAND write: device 0 offset 0x60000, size 0x500000 5242880 bytes written: OK Set the bootarg as follows:= "setenv bootargs console=ttySAC0,115200 root=dev/nfs nfsroot=192.168.1.6:/home/uid/friendlyarm/target init=helloworld" then I set saveenv and reset the board ------------------------------------------------------------------------- Loading from NAND 64MiB 3,3V 8-bit, offset 0x60000 reading NAND page at offset 0x60000 failed ** Read error ## Booting kernel from Legacy Image at 32000000 ... Image Name: Created: 2012-02-19 9:03:06 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2266592 Bytes = 2.2 MB Load Address: 30008000 Entry Point: 30008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Uncompressing Linux........................................................................... ........................................................................ done, booting the kernel. Linux version 2.6.32.2-FriendlyARM (pritam@pritam-desktop) (gcc version 4.4.3 (ctng-1.6.1) ) #2 Sun Feb 19 16:50:18 WST 2012 CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177 CPU: VIVT data cache, VIVT instruction cache Machine: FriendlyARM Mini2440 development board Memory policy: ECC disabled, Data cache writeback CPU S3C2440A (id 0x32440001) S3C24XX Clocks, (c) 2004 Simtec Electronics S3C244X: core 405.000 MHz, memory 101.250 MHz, peripheral 50.625 MHz CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256 Kernel command line: console=ttySAC0,115200 root=dev/nfs nfsroot=192.168.1.6:/home/pritam/friendlyarm/target init=helloworld PID hash table entries: 256 (order: -2, 1024 bytes) Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory: 64MB = 64MB total Memory: 60084KB available (4176K code, 451K data, 156K init, 0K highmem) SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 Hierarchical RCU implementation. NR_IRQS:85 irq: clearing pending status 02000000 irq: clearing subpending status 00000002 Console: colour dummy device 80x30 console [ttySAC0] enabled Calibrating delay loop... 201.93 BogoMIPS (lpj=504832) Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok NET: Registered protocol family 16 S3C2440: Initialising architecture S3C2440: IRQ Support S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics DMA channel 0 at c4808000, irq 33 DMA channel 1 at c4808040, irq 34 DMA channel 2 at c4808080, irq 35 DMA channel 3 at c48080c0, irq 36 S3C244X: Clock Support, DVS off bio: create slab <bio-0> at 0 SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb s3c-i2c s3c2440-i2c: slave address 0x10 s3c-i2c s3c2440-i2c: bus frequency set to 98 KHz s3c-i2c s3c2440-i2c: i2c-0: S3C I2C adapter NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 2048 (order: 2, 16384 bytes) TCP bind hash table entries: 2048 (order: 1, 8192 bytes) TCP: Hash tables configured (established 2048 bind 2048) TCP reno registered NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. NetWinder Floating Point Emulator V0.97 (double precision) yaffs Feb 19 2012 16:45:03 Installing. msgmni has been set to 117 alg: No test for stdrng (krng) io scheduler noop registered (default) Console: switching to colour frame buffer device 100x30 fb0: s3c2410fb frame buffer device backlight initialized leds initialized buttons initialized pwm initialized adc initialized s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440 s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440 s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440 loop: module loaded S3C24XX NAND Driver, (c) 2004 Simtec Electronics s3c24xx-nand s3c2440-nand: Tacls=3, 29ns Twrph0=7 69ns, Twrph1=3 29ns s3c24xx-nand s3c2440-nand: NAND soft ECC NAND device: Manufacturer ID: 0xec, Chip ID: 0x76 (Samsung NAND 64MiB 3,3V 8-bit) Scanning device for bad blocks Creating 5 MTD partitions on "NAND 64MiB 3,3V 8-bit": 0x000000000000-0x000000040000 : "supervivi" 0x000000040000-0x000000060000 : "param" 0x000000060000-0x000000560000 : "Kernel" 0x000000560000-0x000040560000 : "root" mtd: partition "root" extends beyond the end of device "NAND 64MiB 3,3V 8-bit" -- size truncated to 0x3aa0000 0x000000000000-0x000040000000 : "nand" mtd: partition "nand" extends beyond the end of device "NAND 64MiB 3,3V 8-bit" -- size truncated to 0x4000000 dm9000 Ethernet Driver, V1.31 eth0: dm9000e at c4814300,c4818304 IRQ 51 MAC: 08:90:90:90:90:90 (chip) ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver s3c2410-ohci s3c2410-ohci: S3C24XX OHCI s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1 s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000 usb usb1: New USB device found, idVendor=1d6b, idProduct=0001 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: S3C24XX OHCI usb usb1: Manufacturer: Linux 2.6.32.2-FriendlyARM ohci_hcd usb usb1: SerialNumber: s3c24xx usb usb1: configuration #1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. usbcore: registered new interface driver ums-alauda usbcore: registered new interface driver ums-cypress usbcore: registered new interface driver ums-datafab usbcore: registered new interface driver ums-freecom usbcore: registered new interface driver ums-isd200 usbcore: registered new interface driver ums-jumpshot usbcore: regis...stripped-down
usbcore: registered new interface driver ums-karma usbcore: registered new interface driver ums-onetouch usbcore: registered new interface driver ums-sddr09 usbcore: registered new interface driver ums-sddr55 usbcore: registered new interface driver ums-usbat usbcore: registered new interface driver usbserial USB Serial support registered for generic usbcore: registered new interface driver usbserial_generic usbserial: USB Serial Driver core USB Serial support registered for aircable usbcore: registered new interface driver aircable USB Serial support registered for ark3116 usbcore: registered new interface driver ark3116 USB Serial support registered for Belkin / Peracom / GoHubs USB Serial Adapter usbcore: registered new interface driver belkin belkin_sa: v1.2:USB Belkin Serial converter driver USB Serial support registered for ch341-uart usbcore: registered new interface driver ch341 USB Serial support registered for cp210x usbcore: registered new interface driver cp210x cp210x: v0.09:Silicon Labs CP210x RS232 serial adaptor driver USB Serial support registered for Reiner SCT Cyberjack USB card reader usbcore: registered new interface driver cyberjack cyberjack: v1.01 Matthias Bruestle cyberjack: REINER SCT cyberJack pinpad/e-com USB Chipcard Reader Driver USB Serial support registered for DeLorme Earthmate USB USB Serial support registered for HID->COM RS232 Adapter USB Serial support registered for Nokia CA-42 V2 Adapter usbcore: registered new interface driver cypress cypress_m8: v1.09:Cypress USB to Serial Driver USB Serial support registered for Digi 2 port USB adapter USB Serial support registered for Digi 4 port USB adapter usbcore: registered new interface driver digi_acceleport digi_acceleport: v1.80.1.2:Digi AccelePort USB-2/USB-4 Serial Converter driver USB Serial support registered for Edgeport 2 port adapter USB Serial support registered for Edgeport 4 port adapter USB Serial support registered for Edgeport 8 port adapter USB Serial support registered for EPiC device usbcore: registered new interface driver io_edgeport io_edgeport: v2.7:Edgeport USB Serial Driver USB Serial support registered for Edgeport TI 1 port adapter USB Serial support registered for Edgeport TI 2 port adapter usbcore: registered new interface driver io_ti io_ti: v0.7mode043006:Edgeport USB Serial Driver USB Serial support registered for empeg usbcore: registered new interface driver empeg empeg: v1.2:USB Empeg Mark I/II Driver USB Serial support registered for FTDI USB Serial Device usbcore: registered new interface driver ftdi_sio ftdi_sio: v1.5.0:USB FTDI Serial Converters Driver USB Serial support registered for funsoft usbcore: registered new interface driver funsoft USB Serial support registered for Garmin GPS usb/tty usbcore: registered new interface driver garmin_gps garmin_gps: v0.33:garmin gps driver USB Serial support registered for hp4X usbcore: registered new interface driver hp4X hp4x: v1.00:HP4x (48/49) Generic Serial driver USB Serial support registered for PocketPC PDA usbcore: registered new interface driver ipaq ipaq: v0.5:USB PocketPC PDA driver USB Serial support registered for IPWireless converter usbcore: registered new interface driver ipwtty ipw: v0.3:IPWireless tty driver USB Serial support registered for IR Dongle usbcore: registered new interface driver ir-usb ir_usb: v0.4:USB IR Dongle driver USB Serial support registered for iuu_phoenix usbcore: registered new interface driver iuu_phoenix iuu_phoenix: v0.11:Infinity USB Unlimited Phoenix driver USB Serial support registered for Keyspan - (without firmware) USB Serial support registered for Keyspan 1 port adapter USB Serial support registered for Keyspan 2 port adapter USB Serial support registered for Keyspan 4 port adapter usbcore: registered new interface driver keyspan keyspan: v1.1.5:Keyspan USB to Serial Converter Driver USB Serial support registered for Keyspan PDA USB Serial support registered for Keyspan PDA - (prerenumeration) USB Serial support registered for Xircom / Entregra PGS - (prerenumeration) usbcore: registered new interface driver keyspan_pda keyspan_pda: v1.1:USB Keyspan PDA Converter driver USB Serial support registered for KL5KUSB105D / PalmConnect usbcore: registered new interface driver kl5kusb105d kl5kusb105: v0.3a:KLSI KL5KUSB105 chipset USB->Serial Converter driver USB Serial support registered for KOBIL USB smart card terminal usbcore: registered new interface driver kobil kobil_sct: 21/05/2004:KOBIL USB Smart Card Terminal Driver (experimental) USB Serial support registered for MCT U232 usbcore: registered new interface driver mct_u232 mct_u232: z2.1:Magic Control Technology USB-RS232 converter driver USB Serial support registered for Moschip 2 port adapter mos7720: 1.0.0.4F:Moschip USB Serial Driver usbcore: registered new interface driver moschip7720 USB Serial support registered for Moschip 7840/7820 USB Serial Driver mos7840: 1.3.2:Moschip 7840/7820 USB Serial Driver usbcore: registered new interface driver mos7840 USB Serial support registered for moto-modem usbcore: registered new interface driver moto-modem USB Serial support registered for navman usbcore: registered new interface driver navman USB Serial support registered for ZyXEL - omni.net lcd plus usb usbcore: registered new interface driver omninet omninet: v1.1:USB ZyXEL omni.net LCD PLUS Driver USB Serial support registered for opticon usbcore: registered new interface driver opticon USB Serial support registered for GSM modem (1-port) usbcore: registered new interface driver option option: v0.7.2:USB Driver for GSM modems USB Serial support registered for oti6858 usbcore: registered new interface driver oti6858 USB Serial support registered for pl2303 usbcore: registered new interface driver pl2303 pl2303: Prolific PL2303 USB to serial adaptor driver USB Serial support registered for Qualcomm USB modem usbcore: registered new interface driver qcserial safe_serial: v0.0b:USB Safe Encapsulated Serial USB Serial support registered for safe_serial usbcore: registered new interface driver safe_serial USB Serial support registered for siemens_mpi usbcore: registered new interface driver siemens_mpi Driver for Siemens USB/MPI adapter Version 0.1 09/26/2005 Thomas Hergenhahn@web.de http://libnodave.sf.net USB Serial support registered for Sierra USB modem usbcore: registered new interface driver sierra sierra: v.1.3.8:USB Driver for Sierra Wireless USB modems USB Serial support registered for SPCP8x5 usbcore: registered new interface driver spcp8x5 spcp8x5: v0.04:SPCP8x5 USB to serial adaptor driver USB Serial support registered for symbol usbcore: registered new interface driver symbol USB Serial support registered for TI USB 3410 1 port adapter USB Serial support registered for TI USB 5052 2 port adapter usbcore: registered new interface driver ti_usb_3410_5052 ti_usb_3410_5052: v0.9:TI USB 3410/5052 Serial Driver USB Serial support registered for Handspring Visor / Palm OS USB Serial support registered for Sony Clie 3.5 USB Serial support registered for Sony Clie 5.0 usbcore: registered new interface driver visor visor: USB HandSpring Visor / Palm OS driver USB Serial support registered for Connect Tech - WhiteHEAT - (prerenumeration) USB Serial support registered for Connect Tech - WhiteHEAT usbcore: registered new interface driver whiteheat whiteheat: v2.0:USB ConnectTech WhiteHEAT driver mice: PS/2 mouse device common for all mice s3c2410 TouchScreen successfully loaded input: s3c2410 TouchScreen as /devices/virtual/input/input0 S3C24XX RTC, (c) 2004,2006 Simtec Electronics s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0 i2c /dev entries driver Linux video capture interface: v2.00 gspca: main v2.7.0 registered usbcore: registered new interface driver conex conex: registered usbcore: registered new interface driver etoms etoms: registered usbcore: registered new interface driver finepix finepix: registered usbcore: registered new interface driver jeilinj jeilinj: registered usbcore: registered new interface driver mars mars: registered usbcore: registered new interface driver mr97310a mr97310a: registered usbcore: registered new interface driver ov519 ov519: registered usbcore: registered new interface driver ov534 ov534: registered usbcore: registered new interface driver pac207 pac207: registered usbcore: registered new interface driver pac7311 pac7311: registered usbcore: registered new interface driver sn9c20x sn9c20x: registered usbcore: registered new interface driver sonixb sonixb: registered usbcore: registered new interface driver sonixj sonixj: registered usbcore: registered new interface driver spca500 spca500: registered usbcore: registered new interface driver spca501 spca501: registered usbcore: registered new interface driver spca505 spca505: registered usbcore: registered new interface driver spca506 spca506: registered usbcore: registered new interface driver spca508 spca508: registered usbcore: registered new interface driver spca561 spca561: registered usbcore: registered new interface driver sq905 sq905: registered usbcore: registered new interface driver sq905c sq905c: registered usbcore: registered new interface driver sunplus sunplus: registered usbcore: registered new interface driver stk014 stk014: registered usbcore: registered new interface driver t613 t613: registere...stripped-down
usbcore: registered new interface driver tv8532 tv8532: registered usbcore: registered new interface driver vc032x vc032x: registered usbcore: registered new interface driver zc3xx zc3xx: registered usbcore: registered new interface driver ALi m5602 ALi m5602: registered usbcore: registered new interface driver STV06xx STV06xx: registered gspca_gl860: driver startup - version 0.9d10 usbcore: registered new interface driver gspca_gl860 gspca_gl860: driver registered usbcore: registered new interface driver uvcvideo USB Video Class driver (v0.1.0) initializing s3c2440 camera interface...... s3c2440 camif init done Loading OV9650 driver......... SCCB address 0x60, manufacture ID 0xFFFF, expect 0x7FA2 SCCB address 0x60, manufacture ID 0xFFFF, expect 0x7FA2 No OV9650 found!!! S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled s3c-sdi s3c2440-sdi: powered down. s3c-sdi s3c2440-sdi: mmc0 - using pio, sw SDIO IRQ usbcore: registered new interface driver usbhid usbhid: v2.6:USB HID core driver Advanced Linux Sound Architecture Driver Version 1.0.21. No device for DAI UDA134X No device for DAI s3c24xx-i2s S3C24XX_UDA134X SoC Audio driver UDA134X SoC Audio Codec asoc: UDA134X <-> s3c24xx-i2s mapping ok ALSA device list: #0: S3C24XX_UDA134X (UDA134X) TCP cubic registered NET: Registered protocol family 17 s3c2410-rtc s3c2410-rtc: setting system clock to 2142-02-22 22:10:22 UTC (1137426126) Looking up port of RPC 100003/2 on 192.168.1.6 rpcbind: server 192.168.1.6 not responding, timed out Root-NFS: Unable to get nfsd port number from server, using default Looking up port of RPC 100005/1 on 192.168.1.6 rpcbind: server 192.168.1.6 not responding, timed out Root-NFS: Unable to get mountd port number from server, using default
Can some one please give some inputs on how to create a image of rootfs and then program it into the nand.
