hello.i have a problem when try to install wince. first of all my menu ##### FriendlyARM BIOS 2.0 for 2440 ##### [x] format NAND FLASH for Linux [v] Download vivi [k] Download linux kernel [y] Download root_yaffs image [a] Absolute User Application [n] Download Nboot for WinCE [l] Download WinCE boot-logo [w] Download WinCE NK.bin [d] Download & Run [z] Download zImage into RAM [g] Boot linux from RAM [f] Format the nand flash [b] Boot the system [s] Set the boot parameters [u] Backup NAND Flash to HOST through USB(upload) [r] Restore NAND Flash from HOST through USB [q] Goto shell of vivi [i] Version: 0945-2K like this. 1. i press n for download nboot ok. 2. i press l for picture. ok. 3. when i press w for wince nk.bin my usb lost. how can i install wince?is it possible? Thank you.
mini2440 usb problem
When i have pressed W the usb get also lost, but it will be reconnected in 3 sec. And uploading the ce image works perfect. Maybe you can try it on a other pc to know for sure that your pc is not the problem.
my dnw version is 0.50A if anybody want to help me my msn:oguzu@og-er.com.tr Thank you very much.
There is a special DNW version for WinCE: http://www.friendlyarm.net/downloads#software
Is the upload now working? What was the problem? You can find WinCE 5.0 images here: http://www.andahammer.com/downloads/
Hi, Did anyone ever find a solution to the "generic USB Serial". My desktop won't connect to the USB port, so DNW does not work, Windows looks like it's trying to find a driver but it can't? On a side note I've installed the same software on my laptop (DNW and Visual Studio and the everything works great including Activesync. Any idea how to fix it?
Got the same issue.. When I try to download Win CE (w key) I lose the USB connection to the board... and it doesn't come back unless I do a board reset. Seems to me to be a driver conflict between USB2RS232 and board USB... Is there another way to download an image beside the Jtag (I do not have a parallel or serial port, only USB..) Thanks
Hi I had same problem , try using DNW for both serial and usb connections, It should work that way , you may need to plug out/in the usb cable once after pressing 'w'
I get the same problem cannot get the usb connection up. Tried everything. This needs to be better documenteted what to do in windows to properly install usb driver or else nothing works. what do you do when windows asks for a driver where do you point it? etc... we need to get this fixed!!!!
Please give me the link for usb driver software. i installed drivers but it is not detecting mini2440 when i connect it to Pc. I am using windows xp (32bit).
