Hi, I have Micro2440 SMDK. I have converted zImage_T35.bin to uImage_T35.bin using mkimage. I have downloaded embedian-grip-090306-armel-lenny-installed.tar.bz2. I have untared this filesystem on SD CARD in ext3. uImage_T35 is copied in First partion of SD CARD. Now with this, when I download uboot-128MB into memory, it runs properly and when I try to load kernel, booting starts. After Uncompressing Linux .... I get CRC error, System Halted message. I want to know to which memory location I should upload uBoot-128MB and at which address I should load Kernel. While converting zImage to uImage, it displayed that the load address is 0x30008000. TIA Vikas
load address of u-boot and kernel in
This might help: http://narnia.cs.ttu.edu/drupal/node/131 My understanding is that using this tutorial all these issues are handled for you. u-boot is put in the <u-boot> section and kernel goes in the <kernel> section.
I do not want to write even u-boot in Flash until I am satisfied that everything is running fine. Currently I am running Linux+Qtopia from flash.
