Hi. I'm trying to build the given Windows CE 6.0 OS project in the downloads section but it gives 22 errors. I have tried to clone the given bsp with the guidance from microsoft learning center videos but the result is the same. What am i doing wrong ? Some people says they build it successfully but how ? I have installed windows embedded ce6.0 trial + R2 + R3 updates Platform builder R1 for CE 6.0 and visual studio 2005 R1. I also installed WinCEPB60-R3-2009-Update-Rollup-Armv4I too. I'm trying again and again, waiting 45 min long building times and it always fails i'm about to give up. I have atteched the error list and platform.bib please help. Thanks.
Win CE 6.0 OS Building Problem
Hi. I have found a BSP for another processor. When i clone it and try to build it gives errors but when i use the demo project which comes with it, it builds without errors. Although i choose the same drivers and same system components. I can't find the reason but there must be sometihing missing. Has any one had same kind of experience before, any suggestions ? Thanks.
Hi, I've just installed WinCE 5.0 on my FriendlyArm Board mini2440. I've dowloaded from the website the WinCe 6.0 bsp but I don't know how to build it... where I can find an already built image? something like the CE 5.0 on the DVD? Thanks a lot for the help Stranet
Hi Turkay Pekturk, Have you tried building the included platform builder project? Look in C:\WINCE600\OSDesigns\Mini2440\ Works just fine for me... Thank you, Errol
@Errol, What build options are you using? I'm using "Build and sysgen", but it gives me also a lot of errors
@Edje11, I use everything as it is set up when i open the project. On the menu i click "Build" then "Build Mini2440". If i get errors then i Clean then Build. The only thing i change is to select the correct LCD in: C:\WINCE600\PLATFORM\Mini2440\SRC\INC\options.h Build And Sysgen sounds like WinCE5 not 6. Thank you, Errol
Hi Errol, I'm using the given BSP and included project for CE6.0. Although it gives many errors it builds NK.bin . When i download the NK.bin to the board it seems operating good but a after some time while navigating through the menus device freezes and never responses. There should be something missing, i have to solve this problem. Thanks.
Hi Errol, The attached error list is available at the first message. They are mostly like Error 18 ENDIF expected. C:\WINCE600\PLATFORM\TestBSP_2440\FILES\platform.bib You can find platform.bib in the attchment too. I have checked it but found nothing out of order. Thaks.
Hi Turkay, That log still refers to TestBSP_2440. That isn't the included BSP or the included project that i use... Thank you, Errol
Hi Errol, Sorry for that. I attached the latest build output. If you have an output of your project please send me. I would make comparison. There are many warnings also, and they usually point to non existent directories or files. Do you have them ? Thanks.
You seem to have an error while building AMD BSP's component. In my projet, this component is excluded from build : look in solution explorer, open following tree : Solution 'Mini2440'\mini2440\c:\wince600\Platform\mini2440\src\common\ You must see following list of components : abort, AMD, cache, intr, etc... In my projet, AMD component is grey an its name is "AMD (excluded from build)" Hope it helps... domdom
I get 50 warnings, but no errors. Included is my log, but keep in mind that i have really been messing around with my build... :-) Thank you, Errol
Hi.
Many thanks for your helps. Finally i did it.
The steps that i follwed are as below :
1. I deleted everything inside the PLATFORM and OSDesigns directories.
2. I copied only the directory named COMMON into the PLATFORM directory
from a backup of it.
3. I run the Mini2440-CE6-Suite-1001.exe
4. I opened the project with visual studio and deselect the SQL Compact
option from Catalog View. (It causes an error on reginit.ini)
5. I run the build and it succeeded.
{I forgot to change the language to English. I have to rebuild it :( }
I havent tested it yet. I wish it will not get frozen while using.
Thanks.
Hi, I downloaded wince6.0 BSP, is there a procedure out to build it with wince 6.0 on mini2440? thanks for the help, -Sab
hi im building a wince image with the PLATFORM builder and it dose have some errors on SD Card Driver . can any body help i have four error on the project and all of them came from the driver i also used dodoom website instructions thanks
I am building a project in Platform Builder 5.0. In the Project explorer menu under drivers some folders shows (excluded from build). how to remove this ?
@ravindra : i think u need to right click the source files of drivers to be included in the explorer and select the option "Include in build" ( or something similar ) .
hi expert..i'm newbie using arm mini 2440. i am sorry, i have problem in win ce mini 2440. i change password in system of win ce and then i turn off mini 2440. after that i turn on but the screen just show date and "welcome to Win CE". i couldn't access program win ce.. how to repair this? thank you
