I have been following the PDF that is here to try and get Windows CE working. http://www.friendlyarm.net/dl.php?file=download.pdf Following these instructions I can get SuperViVi-128MB working with my Mini2440 with NEC 3.5" Display. I can also get NBOOT.bin to install and work fine through DNW Tool for Windows CE. Finally, I am having an issues when going into the "w" menu selection to install the .bin file corresponding to my mini2440 and WindowsCE. I found the image on the disk that came with my system which is nk_N35.bin, when loading the image into DNW and on the board I get the following error: ---- Clear the free memory Please send the Image through USB Download Address-0x8c200000 Length=0x1b90310 BIN image type unknow OEMVERIFYMEMORY: InvalidImage ---- Then from there DNW hangs up. Let me know if you have any suggestions
Invalid Image While Installing Windows CE
This is a problem if you are using an older Supervivi... http://www.friendlyarm.net/forum/topic/80#590
I am pretty sure I am using Supervivi V2, which I downloaded off of the FriendlyARM website. It says BIOS Version 2 at the top of the supervivi menu when communicating to the Mini2440. Is that version 2? Or is there another place to get it?
There seems to be a conflict between the image and supervivi. Try this WinCE image: http://www.andahammer.com/Downloads/mini2440-en.rar
Hey guys, Just one question.. how to handle that in case of designing my own WinCE (with Platform Builder 5.0). I'm currently using WinCE5, the newest supervivi and the corresponding nboot. Unfortunately I have got the same problem. Is there any fix or workaround how to upload the image? Pls. help I'm frustrated :-( thx!
I followed these instructions to not having your same problems: http://www.friendlyarm.net/dl.php?file=download.pdf
Hey, i have the same problem when i use the image compiled by Platform Builder 5.0. jeangr, I followed this pdf but not fixed the problem.
hi all same problem here... i folow the download.pdf to installing window ce , then after downloading winCE's image, it works winCE runing instanly,but after the power off then s2 select to Nand then power on, nothing in screen and on dwn apear messeage: Start Windows CE... Unknown NAND type any solution..??
You must update the supervivi with the jtag; http://www.domodom.fr/spip/Mise-a-jour-du-bootloader.html
Seems to be same problem as reported here: http://www.friendlyarm.net/forum/topic/235?lang=en
hi all updating through hjtag doesn't solve the problem. I've flashed with newest supervivi version from friendlyarm.net withou any success. probably there's a problem between older SDK (for PB 5.0) and newest supervivi.. will try to generate WinCE image with newest SDK and flash it - maybe this helps (since newer WinCE images can't be flashed through older superviv versions -> maybe also not backward compatible! :] ) will inform you guys if there is any success!
