Hello friends, I am having a Mini6410 ARM11 board preloaded with linux. I got a dvd with that board containing WinCE images. How can i make boot-able SD card and run WinCE on that? Step by step Guidelines are appreciated. thanks in Advanced.
How to create boot mini6410 using SD Card
Hello, Thanks for the link. I tried that, and Format NAND successfully. BUT Running or installing WinEC failed. It shows the than DNW is waiting for transmit data. What is the problem? Am I doing something wrong?
You do not need serial link for superboot. Make sure you have LCD-Mode enabled and you can operate using LCD and buttons on noard. below is my ini: #This line cannot be removed. by FriendlyARM(www.arm9.net) #This file is FriendlyARM.ini and goes in images folder on SD card LCD-Mode = Yes LCD-Type = H43 CheckOneButton=No Action=install OS= Linux VerifyNandWrite=No StatusType = Beeper| LED #################### Linux ##################### Linux-BootLoader = superboot-6410.bin Linux-Kernel = Linux/zImage_h43 Linux-CommandLine = root=/dev/mtdblock2 rootfstype=yaffs2 init=/linuxrc console=ttySAC0,115200 Linux-RootFs-InstallImage = Linux/rootfs_qtopia_qt4.img Linux-RootFs-RunImage = Linux/rootfs_qtopia_qt4.ext3 ################### Android #################### Android-BootLoader = superboot-6410.bin Android-Kernel = Android/azImage_h43 Android-CommandLine = root=/dev/mtdblock2 rootfstype=yaffs2 init=/linuxrc console=ttySAC0,115200 androidboot.console=s3c2410_serial0 Android-RootFs-InstallImage = Android/rootfs_android.img Android-RootFs-RunImage = Android/rootfs_android.ext3 ################### WindowsCE6 ################# WindowsCE6-Bootloader= superboot-6410.bin WindowsCE6-BootLogo = WindowsCE6\bootlogo.bmp WindowsCE6-InstallImage = WindowsCE6\NK_h43-i.bin WindowsCE6-RunImage = WindowsCE6\NK_h43-i.bin #################### Ubuntu ##################### Ubuntu-BootLoader = superboot-6410.bin Ubuntu-Kernel = Ubuntu/uzImage_n43 Ubuntu-CommandLine = root=ubi0:FriendlyARM-root ubi.mtd=2 rootfstype=ubifs init=/linuxrc console=ttySAC0,115200 Ubuntu-RootFs-InstallImage = Ubuntu/rootfs_ubuntu-slc.ubi Ubuntu-RootFs-RunImage = Ubuntu/rootfs_ubuntu.ext3 ############### UserBin ################# UserBin-Image=WindowsCE/NK_h43-i.nb0 userBin-StartAddress=50100000
hi fraser i made the previous steps and it works good with win ce6 but with ubuntu or linux or android i have this pic and touchDevie: /dev/touchscreen-1wire and it stop what is my problem note: i also have h43
Go on Downloads (https://www.friendlyarm.net/downloads ) and scroll down. There you finde a picture with access-data to an ftp-server. You can Download two DVD-images with all sources an binaries including superboot.bin
Good afternoon. I bought a WCE mini6410 when I installed WCE and the lcd does not work, copy of dvd file for the model LCD N43 and my LCD is the H43, can this be the problem?. where I can find the file for this LCD? thanks.
