Hi, I am struggling with my tiny6410 + sdk. I was successful to launch dnz and upload my new kernel yesterday but I screwed somewhere. Now my tiny6410 is not booting anymore. Basically, I connected the board with serial + usb accessing u-boot and uploading kernel. I was always getting the same error Oops 5 blabla while launching the new linux kernel (even when using the one from friendly arm cds). I tried to select "erase nand flash" once (why not? :-)) and from now on the card can't boot. It means I have a white screen and I don't see anything on the serial port COM0 (even with oscilloscope). I was pretty confident that I could save the board by booting on a sd card but I have the exact same thing with it. I flashed a kingston 2gb with superboot (tried version Superboot-6410-20111102.bin and superboot-20110722.bin) and added linux kernel, qtopia and so on. But I obtain the same comportment : white screen and nothing on serial (just high level but no communication). Do you know how I could debug this? I can understand that I erased the uboot accidently on the board but why isn't booting with sd either? Thank you for any help.
tiny6410 not booting anymore
I didn't spend time reading your descriptions. However, I would suggest to get the Superboot up and running first before adding any other things, like kernel, etc. Good luck
Got it working finally. I just flashed the sd card with superboot and didn't add all linux, yaffs, etc. I was then able to upload the kernel and everything through usb and reboot on nand. Just don't copy the friendlyarm.ini that auto-flash the board ! Thanks anyway
