I have 2 mini2440 boards, a 3.5" lcd and a 7" lcd. The 3.5" lcd works on both boards, and the 7" innolux lcd displays a noisy white screen on both boards. What do I do to get the 7" lcd working? Thanks!
7" LCD No display
Hi, I'm new to this, but it sounds like you have the 3.5" images in flash on both boards. You will have to flash the 7" image into NAND before the lcd will work. For WinCE it is called something like NK_A70 Thanks, Errol
I'm running Linux with Qtopia. So which image for that? And where do I find the best instructions to load new image? As you can tell, I'm very new at this...
> And where do I find the best instructions to load new image? Download instructions for DNW: http://www.friendlyarm.net/dl.php?file=download.pdf
I have almost the same problem with 7 inch LCD. I followed this tutorial to include build a zImage. http://members.cox.net/ebrombaugh1/embedded/mini2440/index.html I've used the config_mini2440_a70 config file, enabled the gpio and spi's. Then in boot menu, i downloaded the new kernel file, zImage. After when i boot from NAND, there are only yellow, red, green lines on LCD. What can i do? J2 jumper is on right place, because it was working before. Thanks
