We have written a simple program which sends and receives text, to and from COM1 serial port. PC and friendlyARM devices are connected through serial COM port and the program is executed on friendlyARM mini2440 device. On PC the hyperterminal program is launched with the configurations 115200 8-N-1. The same configurations are used in program running on friendlyARM. While reading from the COM1 of mini2440 device we receive error messages (on hyperterminal console) as pasted below. The data is indeed transferred but with errors. The serial com port of friendlyARM does not seem to work as expected. Please expalin these messages as it leaves COM1 serial port unusable for Dial Up internet Connection. ERRORS: AKY=00004005 PC=02c224c0(ser2440.dll+0x000024c0) RA=00000000(???+0x00000000) BVA=06000000 FSR=00000007SetBaudRate -> 115200Data Abort: Thread=8f53f400 Proc=8e026160 'device.exe'AKY=00004005 PC=02c2284c(ser2440.dll+0x0000284c) RA=02c22838(ser2440.dll+0x00002838) BVA=06000000 FSR=00000007Data Abort: Thread=8f53f400 Proc=8e026160 'device.exe'AKY=00004005 PC=02c2284c(ser2440.dll+0x0000284c) RA=02c22838(ser2440.dll+0x00002838) BVA=06000000 FSR=00000007Data Abort: Thread=8f53f400 Proc=8e026160 'device.exe'AKY=00004005 PC=02c2284c(ser2440.dll+0x0000284c) RA=02c22838(ser2440.dll+0x00002838) BVA=06000000 FSR=00000007Data Abort: Thread=8f53f400 Proc=8e026160 'device.exe'AKY=00004005 PC=02c2284c(ser2440.dll+0x0000284c) RA=02c22838(ser2440.dll+0x00002838) BVA=06000000 FSR=00000007ATI+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C0+SL_GetStatus 0x386C
mini2440 serial port (COM1) error
Hello Sheraz I use the COM0(RS-232) to comunicate with another device and it works fine. I use "minicom" to configure the serial port. Can you execute the command "stty -F /dev/<yout port> -a" to check the configuration of the serial port?? Greetings Carlos
Try turning the serial cable around, I had the same issue when using dnw, turns out the cable I had was "end specific".
Hi all, could i know how I can configure the serial port communication and send/receive data via a serial port. i just configure the HyperTerminal as 115200 baud rate and 8 bit , no check sum and one stop bit and Non flow control but i don't know from where i can configure the serial port com in mini 2440 then i run this command #echo " aNy text......" > /dev/ttsy1 and nothing was send. So could any one help me for solving this problem and how can i receive the data i send from the mini2440 in HyperTerminal and vice versa M.Hamed
Hi all, another question about serials: If I connect the first serial (on micro2440) with my (win) pc and start dnw.exe, I can watch the kernel messages. Even booting from NAND. Do's this mean the kernels output is bound to the first serial? And the first serial is occupied for these purpos? For other communications I have to use another serial? Thanks skip
Can I use COM0(RS-232) for connect with WinPC programm but NO dnw.exe, when OS has worked already? Does send MINI2440 any symbols via COM0 to PC or wait parcel from special download PC software(like dnw.exe), while I power on MINI2440 and MINI2440 starts in BIOS ? Ihar
