hello, i have compiling the u-boot ane make a image u-boot.bin file. after compiling i load on board . i select the NOR mode and give the command b so the qtopia operating system is run on the board but there is a problem if i select the NAND mode and swich ON the board there is not running the qtopia os on board . so if any one have the solution so please give me a solution i use mini2440-c792875993e8c2dd23bba8adebe209df21f99696 source of u-boot.
u-boot
More details please. You use supervivi in NOR mode to load u-boot. You use DNW on Windows or USBPush on Linux to send the file? You use command D or B?
after loading the image file on the board and change the switch mode to the nand. on that time the os is not start by it self but i give command b from Dnw software to keep the switch mode in nor so the window is start so please help me to solve this problem
