hi everyone, I'm using micro2440 board. And i'm using Vs2008 to program. My problem is how to use an application on pc to control the board via usb port. If anyone has performed, give me a guide please! Thanks in advance Best regards, Tran
Application on PC control Mini2440
Hi Friend Are you using linux or windows ce ? iŽll assume that is windows because vs2008 What kind of control are you plannig to do ? file transfers, leds, ... ? regards, Marcelo
Hello Marcelo, Thanks for replying me. I'm using Win CE. First, I want to control leds from a PC (ex. click a button in an application on PC, then the led light up). Furthermore, i have trouble with GPIO driver (control simultaneously many pin in a port) and PWM driver (20MHz frequency PWM) Thanks very much! Best regards, Tran
hello everyone, i'm using WIN CE 5.0 for mini2440,too. And now, i want to develop applications on its with C# (Visual Studio 2008). i have some questions : -the first, Do VS2008 have support for mini2440? -what do i must do anythings to write a basic progarm ? -and suppose that, i write and build a application then down to mini2440 through USB port or FTP protocol, do that application work ???? If anyone has performed, give me a guide please! Thanks so much. KHoa
